POWERMATIC 66 THROAT PLATE
Doug Reynolds
I recently did some spring cleaning on my Powermatic 66 table saw. I aligned the top so the regular throat plate opening was centered on the saw blade. Now, when I tilt the blade to 45 degrees and use the larger throat plate the blade hits the left side and, does not go through the hole. The owners manual does not specify the optimal location of the throat plate to accomodate dado blades and miters, etc. Can anyone advise what would be the best way to align to top to the regular throat plate opening?
