Edgebanding with raw veneer techniques?
So I have done a little edgebanding with iron-on material. But now I have a project with a lot of panels. The panels are veneered with raw curly maple veneer and I have all the matching edge strips pre-cut.
Does anyone have suggestions for gluing the strips? Choice of glue? Clamping? Other techniques that help?
Thanks for any help.
T.
Re: Edgebanding with raw veneer techniques?
Tony - Memphis
I'm no expert, but I have done a few tabletops. Nothing exotic....no tricks. I normally use hide glue (Franklin). I make a caul lined with cork (I get it in rolls at Michael's - get their 40% off coupon - or Hobby Lobby - they have coupons too). I cover the cork with shipping tape to prevent sticking. I use lots of clamps. I glue two opposing edges oversize, then trim, and then glue the other edges. I trim with a veneer saw and clean up with sandpaper. I just completed a round tabletop using the same method. It worked out pretty well. I used a band clamp for that one.
Tony
Tony,
Your technique is similar to what I was thinking. The cork idea sounds like a good one. Thank you!
Tommy
paul in AZ
Nothing fancy. A caul and plenty of clamps, Tightbond glue, + block plane.
I make my own edge bands.
I don't see a need for cork if the caul is smooth and the edge band is hardwood.
Similar
I make a caul (unless I have one) that's 2" longer than the edge to be banded out of a piece of 2x4. The 2x is slightly tapered from the center to the ends by about 1/8-3/16" (up to 5' length) with the center point sanded round and smooth. I then tape the face to prevent sticking. The banding is glued (T-B II or III) and applied to the edge, then the caul is clamped with one clamp on each end and one in the center so that the tapers flatten out and I get an even glue squeeze on the whole length. The 2x puts even pressure on the entire length and saves on clamps that can create slight impressions.
I use the same method to glue up butcher block tops.
Jesse Cloud
If you will be doing a lot of panels, it might be worth it to make the jig we use.
First, you need a piece of melamine or something impervious to glue, a few inches larger than the panel. Then, two straight wood pieces for fences, a little longer and thicker than the panel. Screw one to the edge. Route a couple of through grooves 90 degrees to the fence. Drill holes in the other fence so you can put a bolt and handle through the groove and fence. You now have two fences/cauls, with variable spacing between them.
Make a sh**load of wedges (instead of clamps) and a caul. Snug one side up to the fence. Put the caul on the other side, tighten the other fence near the caul, use wedges to tighten the caul.
If I am doing a large run, I'll have half a dozen of these going at one time. Also works for odd shapes if you shape the cauls. Not limited by the number of clamps you have.
I just use POT, plain old titebond.
Keith Newton
I never liked having to veneer edges either, so I usually rip 1/4" strips from solid wood, then glue and brad that to the edge before veneering. It is a lot easier and faster to apply.
Most of the time, there are some common widths, so I try to do both edges of the 8' substrate, before cutting the lengths, which eliminates a few steps of cutting those edges to match the length of the substrate.
You can flush trim with a hand held router, but it is hard to keep from tipping over occasionally, so on larger runs, I set up a straight cutter on the table router. I usually screw on a sub-fence on the table router, leaving it about 3/8" above the table, and about 10" tall, to make keeping it upright easier. I then climb cut, with a feather board set fairly tight. A 3/4" or larger cutter, will allow a faster feed rate than anybody needs to even try for. Then a light touch on the stroke sander, will leave a really clean flat panel, ready for veneering.
This method not only provides a lot tougher edge than a veneer, but leaves about 3/8" fudge factor for trimming down, in the final fitting stage.
Jim in Burlington Ont.
Jim in River Oaks, Ont.
Experiment... see what works for you
HC Sakman
Hi Tommy,
Cut the strips of veneers 1/16" or so (each side) wider than the edge, use PVA glue on both faces and then use masking tape as clamp, making sure to stretch the tape slightly and it is a good quality masking tape.
OR, use 1"x1" cauls then clamp them. In this case, veneer strips don't need to be glued nor need to be the exact size, use wider strips. You can still use masking tape here and there to hold the veneer and caul in position while you place the clamps.
Chico
Bob
Bob
Hot hide glue has zero "creep" good to do edge banding with, it Bonds great. Patrick Edward at AFSM sells Old Brown Glue and I love it because it has a long working time for complex glue ups.
PS...
Tony - Memphis
I tried to get fancy with some satinwood on my first top. I managed to keep everything in order and kept cut the edge banding from the same pieces for the corss banding to get a "waterfall" effect of the grain. Great idea.....not....when th egrain turns from horizontal to vertical, the light and dark "stripes" reverse and it doesn't look lijke they line up at all! Oh well, I tried. Might be more beneficial for other woods.
I like the cork because my veneer is not always perfect. The cork takes up some of the variation in thickness and a bump here and there. There is a layer of cork and laminate against the edge banding. That worked pretty well.
Thought I had a pic of another top (square) here at work but I can't find it.
Tony
Here is a step in the round one. i used the blue tape to keep everything in place until I got the clamp on. Things didn't go as planned....The blue tape saved the day.
Re: Tape Clamps
Tried this as well. Sometimes it worked great, but when banding with figured wood it was kind like whack-a-mole with bumps and I wound up with the the whole length taped solid.
Steve Jenkins
I place my clamps on a flat table then use 1/4" thick strips to elevate the panel. I cut the edgebanding 1/8" wider than the thicknes of the panel. I make full length cauls from 3/4 melamine that is ripped to 1-1/4" for a 3/4 thick panel. The width isn't critical as long as it sticks up above the panel.My clamps are usually around 8" apart. I clamp for around 30 minutes and before removing the clamps use a sharp plane iron to trim the veneer. Just lay the plane iron on the panel bevel up and slice against the melamine, remove from clamps flip over the panel, retighten every-other clamp and trim again. I use pva glue and apply it to the panel edge only.
Steve
