Re: There are two planes to consider
Rick Christopherson
Lee,
I was well aware of the geometry change on the angle, but if you do the math, you will see just how trivial your argument is. To accurately go through this, I created a SolidWorks model representing a 10" circular saw blade crosscutting a 3/4" workpiece, at typical blade height, and where the front-to-rear blade skew was 0.010".
The difference in length of the cut at the top and bottom of the workpiece is 0.0011" (0.001"), and the angle is 0.09 degrees off perpendicular. The curve of the cut is so trivial that I can't get this $8000 cad system to even measure the radius.
Just blade wobble alone is going to far exceed these numbers. That's not to mention, that I guarantee that your blade bevel setting is not accurate to within 0.09 degrees from perpendicular. Simply turning on the saw will knock this calibration out of alignment due to gear lash in the worm gear.
The principle of this need for parallelism is blown out of proportion, and the people that keep harping on it are simply repeating what they've heard elsewhere without critically performing the mathematical analysis of it.
As you read through the majority of internet postings on this topic (not just this forum), you will see that most people assume that this is a critical adjustment because it impacts the square of the cut relative to the miter fence. This is why so many people mistakenly harp on the topic.
It doesn't impact squareness to the miter fence. It impacts squareness of the "bevel", but it is so trivial of an impact that it is not worth messing with until it becomes visually noticeable when looking down on the blade.
