200+ woodworking book reviews
OT Garage Door Openers
Gary Smyth
As soon as the weather breaks and I can clear the garage, remove the existing lights, I want to install two new used garage door openers. The install should be fairly straightforward but I'm concerned about the 2x4 trusses. The openers will have to be anchored to one or more truss. Will the truss be able withstand the hanging and lift of the door without undue stress? Should I sister SOMETHING on to the truss? There is nothing above the truss as they are the roof joists also and are on 24" centers. The doors are ply panel with windows. I'm guessing 100 pounds. I'm planning to use slotted steel as hangers.
Re: OT Garage Door Openers
Mark Nowicki
A slotted angle iron laid along the joists and secured with lag screws will support the opener and the weight of the door.
Mark
Bruce, a MN Galoot
As I understand these things, the opener doesn't have to support the weight of the doors. They only lift the door (with the aid of the springs), but the weight of the door itself is carried by the track. A couple light angle irons will be enough to hold the openers.
Jason Roehl in Lafayette, IN
Correct.
Typical installation of a garage door opener is to use 3 pieces of slotted/holed, 1" galvanized angle steel. I piece gets screwed to the ceiling across two joists (perpendicular, whichever direction they run), then the other two pieces are bolted to that piece about 12" apart and form a vertex at the attachment point on the opener (sometimes a 4th piece attached to the opener). The other support for the opener is the drive track where it attaches to the header above the garage door. Placement here is critical for good operation.
If you don't have the manuals for those openers, search the web for the model and I bet you'll find online directions. They should be pretty straight forward.
Also, as someone else alluded, the garage door should be at virtually neutral balance if the springs are properly set (garage door springs are best left to pros--they can be deadly if you don't know how to set them).
Jason
Dick Coers
Please clarify if you are concerned about hanging door weight, or opener mounting. All the load for the opener is at the door header where there is a bracket to hold the opener track. You could almost hang the motor end of the opener with bailing wire, but use box store slotted angle iron. There isn't much static weight, and load is no concern at that end.
Opener mounting is the first
Gary Smyth
concern. Door weight is matters only if it will affect the condition of the truss
Dave Bair
My garage configuration is exactly the same as yours. My opener lifts an 18' steel door with no problems and no reinforcement of the 2x4 truss. Mine is set perpendicular to the truss.
Re: Opener mounting is the first
George Koch
Gary, No weight of the door is tranferred to the opener, it remains on the tracks and rollers. The only weight your adding to the trusses is the weight of the opener itself. The torque applied to lift the door is all horizonal on the drive chain of the opener. George
