A55 Smoothing Plane
Epoxy Floor Paint Removal?
tom
So about 5 years ago I did our garagre with an epoxy paint and sand. It was a Abitron product. Spent almost $1200 on all the materials and prep. Now wit large areas peeling off I want to see about removing it. I have contacted a few companies that grind concrete and the cost is $1500 and up. Close to $2500 if I want it polished.
So has anyone here done a "removal project" of this nature?
Advice is most welcomed!!!
Re: Epoxy Floor Paint Removal?
Your local rental jernt will have a rotary concrete floor grinder available. You will have to buy the set of "stones" which should be about $100. It is best to do it wet to control dust and keep the stones from clogging. Some grinders have a hose hook-up for a continuous flow of water.
Other equipment needed waterproof footgear, mask and hearing protection.
Should take you about a day for a 2-car garage. You should empty the garage and shield anything on the walls with plastic as the concrete splatters will stick to everything. If your driveway is paved, you should keep it wet and plan on power washing the runoff.
Yeah. Messy Messy Messy!
I have....
John in NM
But my experiences won't help you much, we had a fork lift and a ton of lead bars, and a piece of snow plow blade for a scraper. It was kinda fun :D We also made a grinder out of some plywood, self-tapping screws, and a floor buffer for areas where we couldn't get with the forklift. Didn't work as well as the scraper though.
If it were me, I would just chip at it with a heavy tile scraper and figure I'd get most of it over the course of a year. But then I'm cheap, really cheap :D
Next in line, I'd find a grinder to rent as Mark suggests.
Would muriatic acid work for this?
No
While it will etch the exposed cement surfaces, it will do nothing to the epoxy surface.
Grinding off the plastic surface is the only way (TIKO) to do this.
Use interlocking tile for $3 sq ft
Dick Coers
and maybe cheaper and easier than working with that epoxy
