how to post pictures
Sevilla
Hello, I tried to include some pictures from my ipad on a previous post with no results. Can anybody tell me how to do it?
Thanks
Sevilla
Thanks
Re: how to post pictures *LINK*
John McGaw
Pretty self-explanatory. Basically, keep the size within bounds and make sure that you are a 'profiled' user.
http://www.woodcentral.com/faq/#photoupload
Sevilla
i do not see the box with the phrase : upload embedded file.
I can post an image only if I start from my profile but not otherwise.
I see the phrase: to include an image with your text, if it's on the internet provide the UTR but nothing That I can do. Is the ipad the problem?
Thanks
Here's the drill
First, have a look at the FAQs (link in the gray navigation bar above). There you will find an overview and specific instructions.
You may link to a photo that lives on the internet and has a valid URL without registering a WoodCentral profile, using the Optional Image URL box below the message textbox.
If you want to upload pictures from your computer in line with your message, you must be a registered member of WoodCentral (i.e., have a profile). Creating a profile takes only a few minutes. Then you will see the "Uploaded Embedded File" option above the text box, along with smiley icons and text formatting options.
[NOTE: If you use multiple computers and/or browsers, be aware that WoodCentral places a small cookie file on your device every time you post. You must use the exact spelling (case sensitive, including spaces and punctuation) as in your proflie. If you get an "Invalid Password" note, it is usually because you have not matched your registered username. You can correct this on any device and/or browser by going to Set Preferences and making the correction there.]
Currently, image files must be smaller than 100 Kb in size, so if you have full-sized camera image files, you'll have to resize and/or/ compress them to under 100 Kb, or else the server will not accept them.
If you have further issues, you can try to work through them using the instructions in the FAQs, or you can e-mail me directly.
It's quite easy, really, but you do have to be exacting about your username and address.
Ellis Walentine, Host
WoodCentral.com
