Rescue From The Scrap Bin
John McGaw
This project has some history. A few years ago I started making a painted Shaker-style blanket box for a young(er) woman who was living with me at the time. Things didn't work out and she wound up leaving before I got beyond the process of milling the wood and gluing up the panels. The panels have been sitting there glaring at me in the shop for four years now and in a manic mood I decided to do something with them. I had been using two lower shelves on my library bookshelves as my wine cellar and it has become clear that that space would be needed for actual books so I set out to make a wine rack.
The pre-made panels for the chest were not a perfect fit for the purpose but I pressed on and adapted them. Instead of dovetails I used many (44?) pocket screws to hold things together. I chopped down the former top and made the bottom platform and glued up one remaining maple board to make the top. The boards destined for the original chest base became the vertical rack supports. The horizontal rails are made from a nice clear white pine board from the lumber rack (a seriously tedious bit of work turning a big board into 64 24"X3/4"X3/4" sticks with tapers at each end). The rails are bradded to the vertical supports while the supports are attached to the top and bottom using big Confirmat screws left over from my bookshelf project. I had to go and buy some clean casters and some stout screws to attach them but everything else was sitting in the shop.
Unfortunately I had not matched the wood in the original panels, the intent having been to paint the chest and this clearly shows in the photo. As it is, it will not be on prominent display and will likely live out its life in a cool dark corner of the basement so it doesn't matter much. Curiously, when I loaded it up I found that space for 64 (4X8X2) bottles was not enough so I will have to drink up the straggler and then be more careful about my purchases in the future.
Re: Rescue From The Scrap Bin
Or build one more
Re: Or build one more
John McGaw
MISSION ACCOMPLISHED. I have killed off the straggler and everything now fits.
