THE WOODRAT IS BACK!
Testing my smarts
Testing my smarts
Testing my smarts
John Pappas
Re: Testing my smarts
well, I'm not sure
John Pappas
Is this the way scanned items work. I thought the scanned item would appear without the need to click on the little icon. :(
Re: well, I'm not sure
Lee Schierer McKean, PA
The scanned item doesn't work either...... >(
Scan
to a .jpeg file and try again
Re: Scan
John Pappas
thanks, will try later.
No problem...
Larry Rupprecht
Your scan worked for me.
John McGaw
It works for me. Kinda. Sorta. That means that I can download the content and look at it using my PDF viewer app but if I click on it in FireFox it won't open directly. Haven't bothered to dig any further.
Re: Scan
John Pappas
One more test
Re: works fine for me in Firefox
Joseph Mulherin, sr
Duhhhhh...
Jesse Cloud
Both scans worked for me using Safari on a Mac.
Testing my smarts
Merle
I use Chrome and had to double click the first one for it to open. The second one appeared in the body of your message.
Seeeeee?
You too CAN do it :D
One click in Opera
JohnT
Original Message had only a PDF icon, but one click opened the message in a separate window.
Using Opera as my browser.
Ron in Sterling, CT
Using firefox, I could open the scan in the original message by double clicking on the adobe icon.
Ron
Thanks for all the responses.
If your scan.....
....was a photo of Norm Abrams wearing a bunny suit, it worked.
T.
Geeeez, back to square one...
Hmmmm.... speaking of pdf's
Tim Greif - West of Chicago
Your pdf in the message loads with a single click for me in both Google Chrome and IE8.
And speaking of pdf's, I was not aware that you could attach them. How did you do that? Just upload like normal jpg files? And is there a size limit on them too? Geez, I still learn something every day here.
Re: Hmmmm.... speaking of pdf's
John Pappas
Tim,
Actually, I flunked the smart test..my software for my printer/scanner has options for the scan: JPEG to file, JPEG to e-mail, PDF to file, PDF to e-mail. Not knowing any better I clicked on 'PDF to file' and proceeded. Now, I am assuming something...size was not a problem because the document was accepted and posted just as it was scanned. On my second scan, 'JPEG to file' I had to change resolution before the message would post.
John
OK, I tested it.  100K is limit on pdf's too.
Here's a test. The original whole document was 220K, rejected by the uploader. I extracted the first page and turned it into a single pdf at 11K. Uploaded fine. Displays with the little adobe symbol.
This is a neat little feature that can be used to display parts lists, diagrams, etc without having to convert to jpg format, as long as the size requirement is met. The only thing I don't know how to do is tie a description or text prompt with the little Acrobat icon. Maybe one of the admins will chime in.
On my system, it loads with a single click in both IE8 and Chrome. Your system may behave differently depending on how your browser or Acrobat is setup. There are different ways to have pdf's display in browsers. You can (1) have them appear inside the browser with a built in Acrobat display plug-in, (2) download and display transparently in a separate window using your own Acrobat software (Reader or Acrobat pro) with no prompts, (3) download and prompt you (for security reasons) to accept it and display it in your own Acrobat software. I have mine setup this way because the Chrome plug-in to display pdf's has limited functions. I use Acrobat Pro. The little Acrobat icon below will display one page of a chemical resistance table.
Description
Tim, it seems to me that you can just type whatever discription you want before or after the place in your message where you upload your file. For example,...
Here is a Stanley Plane Dating Flowchart from our Badger Pond Articles department:
File size limits
The size limits for the various allowable file types may be viewed by clicking the little round blue button just above the message text field on the message form.
It'd be possible if we could edit the message.
If we could edit the final html code of the message, we could embed the text descriptor, the same as when we code a hotlink to an external document using "a href" string. You just put the descriptor in the code right before the "/a" code at the end of the string. You'd then have a hotlink to the document by clicking on either the acrobat icon or the text descriptor.
Using your example, I copied the source code for the link to the document for stanley planes and added the text descriptor after the icon to have it appear like this:
Stanley Plane Document
Probably not at the top of your to-do list, but if people find this useful, it may be worth pursuing.
