ADVERTISE HERE - FREE TRIAL
Band Saw Blade For Resaw
Tom Rex in TX
In your humble opinion what is the best brand of resaw bandsaw blades?
Where are they sold?
TIA,
T Rex
Re: Band Saw Blade For Resaw
Jim in Burlington Ont.
Jim in River Oaks, Ont.
I use a 3 TPI 3/4" Timberwolf, have used one for years as my Go To resaw blade...
Take care,
Jim
Bruce, a MN Galoot
I have two, a 1/2" Wood Slicer from Highland Hardware that cuts really well, and a 1/2" Lenox Tri-Master, carbide tipped and very expensive. However, it can be resharpened. The Wood Slicer has a thinner kerf and takes a bit less power, which is nice.
Timberwolf by Suffolk Machinery
Woodslicer by Highland Woodworking
I've tried both, I like both. I wouldn't get more than a 1/2" blade.
http://www.supercutbandsaw.com/
GolfSteve in Calgary
In my humble opinion, the Laguna Resaw King is the best I've used. I bought one as a prequel to my guitar project and am amazed at how smooth it cuts. With that blade I've repeatedly achieved tolerances that are quite astounding - eg. cutting a bunch of strips exactly 67/1000" thick (1.7 mm), then resetting the saw, cutting a bunch of strips 52/1000" thick (1.32 mm). The cuts are so smooth that I pass some 400 grit sandpaper paper over the cut edge a few times, taking the strips down to their final thicknesses of 65 and 50/1000"
However, for general furniture making work, including sawing your own veneers (say 1/8" thick), I would not spend the money on the $250 carbide tipped Resaw King. Just buy good quality $30 blades, adjust the tracking properly, and replace them often.
ps. I also have some bent-up carbide Lennox Tri-Master blades that came with my used 18" bandsaw. The Tri-Master blades are much thicker (stiffer) than the Resaw King - so thick that I can believe they would fail more quickly due to bending fatigue, as you read about on the Internet, than the Resaw King. However, the Lennox blades were much less expensive and are really sharp.
Bob
Bob
Laguna Re-saw King is what I use. I have the same one for 6 years its 2TPI X 1" I cut 1/16" veneers no sanding required. I sent it back to be sharpened 2 years ago and they even replaced a few teeth. Not cheep but you get what you pay for so why not just spend the money one time and have the best.
jcousins
laguna resaw king. laguna has great customer service for their blades - fixed a broken weld, sharpen. my only xperience has been with their bs blades.
use it for resawing veneers xclusively
jerry
Bob
Bob
Ironic, I had just cut a spalted sycamore log 6" using my Laguna King blade and must have hit something! I need to send it back to be sharpened, I think I will ger a new one as well. I got about number of 3/4" X 18" from 2 logs
