200+ woodworking book reviews
How would you cut roped brass tubing?
Tim Greif - West of Chicago
I need to cut down a piece of 1-1/4" diameter roped brass tubing for a lamp I'm making. I've done plain brass with a standard tubing cutter, but the roped tubing diesn't really lend itself to that method due to the uneven indentations and shown in the picture. I need the cut to be pretty much dead perpendicular to the tube axis to make sure the lamp shaft sits straight.
I have access to a table saw, RAS and CMS. No band saw available. Any thoughts?
Re: How would you cut roped brass tubing?
Miter box and fine hack saw blade?
You can make one and use it in conjunction with a hack saw.
I really wonder if it is pure copper? Most of the stock I have seen like that are copper plated steel as pure copper is pretty soft. In any event I would saw it off with a fine hack saw blade then if necessary true the end with my stationary sander - if you don't have one a file and square would work as well - just a little slower. I think you would have more work removing the jagged edges - not to mention the safety aspect - trying to do it on a wood saw.
Depends on how heavy it is...
John in NM
I cut aluminum and brass with a chop saw.
If the tubing is really light gauge, any blade wobble will dent the end. Obviously, you should check that it is non-magnetic before doing this. If it's plated steel, you won't do your blade any favors.
If the tubing is fairly thin, you can cut it more easily with a fine saw like the blades Xacto used to make that went with their aluminum miter box. Or a jeweler's frame saw if you happen to have one. They cut smoother than a hacksaw, but won't give you as straight a cut as the Xacto saw.
Fill It First
I would get some wood doweling that matches the ID and push it into the interior (leaving enough the grasp and pull out later, past the cut location. This will support the tube and prevent it from deforming as you cut.
If you find that it's solid brass (rather than brass plated steel) you can cut it easily on your band saw by taking lite cuts while rotating the tube so you don't cut straight through the dowel. You then pull out your support dowel along with the waste piece.
If it's steel, you can clamp the waste section in a bench vice and the dowel will help prevent crushing the tube. Again, take shallow cuts without cutting through the dowel.
abrasive cut off wheel in a right angle grinder
Bob Entwisle in NJ
Put a piece of blue tape around it where you need to cut it, make sure the tape meets up perfectly, that gives you a square cut line, and then cut it.
I vote for a hack saw.
It's only brass, or brass plated steel, just mark it square (the blue tape) and cut it. Be gentle if you sense that it wants to bend under the pressure of the saw etc. just take it slow.
If it's 2 inches longer than you need it, try this by first cutting one inch off, if that goes well, go for the money cut, if not rethink it while there's still enough material left to try something else.
Please let us know how you make out with it.
Bob in NJ
Jason Waters
I would cut it with a hacksaw as well. Fine tooth. Using cutting oil. A little long.
Then square it up on your disk sander using a miter gauge. To length.
If you don't have a disk sander, drill a perpendicular hole the diameter of the rod in 3/4" ply and slide the piece through and use a file to make flush.
As mentioned, if the tubing is thin and crushed easily, filling it with a dowel will help.
I can probably skin this brass tube some other ways too but that's two I thought of
Jason
JMOHNIKE
I have used a Dremil with an fiber cutoff wheel for similar stock. Just use a soft touch and cut it a little proud so that it can be touched up with a sander.
Hacksaw and a file in about 30 seconds
GolfSteve in Calgary
Hacksaw and a file in about 30 seconds. Really it's that easy. Cut a bit long using the hacksaw, square the cut off up using a file. The hardest part is not squishing or marking up the tube in your vise.
ps. I read a recommendation above about cutting this on a bandsaw. I've also read that cutting cylindrical things on a bandsaw without proper support is a recipe for disaster if the cylinder starts to spin.
Re: Band Saw
Very true.
Workpiece must be supported (I use a sled) and secured. I've cut lots of grabby PVC this way without a problem other than the "dust" flying all over everything.
