Door finishing routine - shoot holes please
David Weaver
I have to do about a dozen and a half raised panel doors.
The finish is going to be target WB shellac under EM6000, and I'd like to spray everything I can (can't do solvent based shellac).
I'm thinking that in order to minimize the effect of shrinkage in the panel (i.e., revealed edges with no finish), I will probably pad the shellac on two coats just in the panel bevels, just enough to make sure the entire bevel is covered all the way to the edge.
Then assemble the doors and go about the regular business (like two coats of shellac and two or three of lacquer.
Anyone with experience have thoughts about that being reasonable?
Re: Door finishing routine - shoot holes please
Pete in Holland, MI
Most of my woodworking occurs in the winter time here in Michigan.
All past raised panel doors were first stained with a foam brush (helps get stain into the panel joints. One coat of thinned oil based poly (thinned maybe 20%) applied in the flat, and worked into joints, then normally 2 more coats of uncut oil based poly applied in the flat.
In the 50 or so doors made over the years, have not had a problem with any shinkage.
I think part of the key is using adequately dried wood, and building them in the winter when humiditiy is low, and panels are at their smallest.
Pete
Dick Coers
What species of wood? One coat should be plenty, it's just for color. Do they recommend shellac for a seal coat? Another consideration is that it's starting to get the spring humidity around here, but the wood might just be at it's narrowest for the year.
Howard Acheson
Waterborne shellac and waterborne lacquer are almost identical for all intents and purposes. Both are basically acrylics and will give very similar results. That being the case, there is not really much to be gained by using both. Pick one and do the whole project with that one.
David Weaver
Target's literature (if I can remember correctly) says you can put the WB lacquer right on the wood. The reason I want to seal with shellac is for color, even if it's just a little.
It doesn't make a great deal of difference, I suppose.
(the cabinets are cherry, unstained. It's my kitchen, so I only have to deal with the wife for leaving them "old" style without stain)
Completely finish the panels,
Merle
then mask them off when you finish the frames.
