What would you call these?
A.J. Hamler
A.J. Hamler
On the underside of a reproduction folding table I've made there is a wooden locking "spring"-- a thin slat that snaps into mortises on each folding leg set to lock the legs in the upright position. The spring is attached to a block mounted in the center on the underside of the table. Holding it in place are two metal pieces measuring 1/2" x 1-1/2" screwed to the locking spring and into that mounting block, as shown here:
Now, what the heck would you call those two little metal pieces? I've been thinking of them as "keepers," but now I'm thinking that "cleats" would be more accurate. Any thoughts?
BTW, here's the finished table:
Thanks!
A.J.
Re: What would you call these?
Jim Toews
I've always called them mending plates. I guess one could call them whatever one want based on how they're used.
Larry
Did you make that chair? Plans?
Thanks
Roger Rayburn
Yes, mending plates. Find them with corner irons and corner brackets at your hardware store or home center.
Dave Nichols
I would call them retainers
Solid hardwood table leg immobilizers is the government name for them.
A.J. Hamler
A.J. Hamler
Yeah, but if I call them that then they'd cost $237 each.
A.J. Hamler
Thanks!
A.J. Hamler
You guys are all correct, in that the metal thing itself should probably be called a "mending plate," but since I'm not using them to join to pieces together I'm not sure it fits. I think Dave's suggestion hit it on the head, though, so I'll call them "retainers." It describes what they do perfectly, and better than "keepers" that I came up with.
Thanks, all.
A.J. Hamler
A.J. Hamler
Yeah, I made the chair, but not from plans. On the other hand, after making the chair I wrote the plans. You'll find them in the August 2012 issue of Woodworker's Journal, and in my upcoming book "Civil War Woodworking, Volume II," coming out this fall.
The chair is based on an original that I own.
A.J.
Re: Thanks!
Roger Rayburn
A.J. Now that we know you are the author of the chair, and therefore a celebrity, would you be interested in creating an armless folding chair that could be "rationally" adapted to provide extra seating aesthetically consistent with dining room furniture? As our needs for chairs expands, our storage capacity does not. We use some steel folding chairs and that just doesn't cut it.
