Who will be the first... *LINK*
John McGaw
...to try to reproduce this in wood? I am endlessly fascinated by the creative process (and more than a bit intimidated most of the time).
The Magic Expanding Table Trick
Re: Who will be the first... *LINK*
Alan Young
Invented by London upholsterer Robert Jupe *LINK*
Alan Young
registered as patent 6,788, on September 11 1835.
Robert Jupe's expanding Table
Bob
Bob
How about this one
http://youtu.be/CIEiqzVjYCE
John McGaw
I've got to say that I like that better than the one I posted if no other reason that it appears to be wood. Wonder how something like that would hold up to seasonal wood movements?
Bob
Bob
Ive seen a lot of these and they are mostly laminate I think. Cool none the less.
Re: Invented by London upholsterer Robert Jupe
John McGaw
Nice, but not quite the same thing since the Jupe table simply opens up gaps into which one must insert leaves. The idea of a table that (effectively) stores and inserts its own leaves is the part that fascinates me.
I already did 6 1/2 years ago *LINK*
Rick Christopherson
Actually, it was longer than that. The original Jupe table I made was 15 years ago. The revised version with better mechanics and motor operated was 6 1/2 years ago.
Edit: Oh, because he used clear plastic, I didn't notice at first that Dearden incorporated the self-storing leaves that D.B. Fletcher had developed many years ago. I've started that design myself, but before it was finished, I discovered that the alleged customer was just a woodworker trying to scam me out of design information. (I get a lot of bogus inquiries from people pretending to be real customers. This guy actually made past my initial screening before I caught on.)End Edit
I get a lot of inquiries from people wanting to replicate or reverse engineer my design, but I don't give that out. There have only been a couple of photographs that show the hidden mechanism below the table. The curved arms in Dearden's design suggests that he was probably inspired by a photograph I had found 15 years ago, and is required when you cannot use 3D design for the clearances. With 3D design, the links can be straight (stronger), but each arm has to overlap at least 2 other arms, and it gets very complicated.
The biggest difference with my design that no one had accomplished prior to that, was that the table doesn't need to rotate to change. A right-angle gearbox drives the whole mechanism, instead of spinning the skirt of the table.
For this last version, I motorized the gearbox using a (then new) Festool C12 motor (3-phase servo motor), gearbox, and controller. This gave the table compact battery operated power.
In the video below, the table is nearly silent, but the automatic volume control on my cheap still camera increased the sound level a lot. So it makes the mechanism sound like a freight train. To put it in perspective, I didn't know the radio was even turned on in the background until I later listened to the video.
http://www.waterfront-woods.com/Projects/RoundTable/TableBlog.html
