(Message Deleted by Poster)
Boy, I wish there was a warehouse
Henry Higginbotham
full of this stuff, right across the street from me (and that they'd charge my toys to Bill Gates or somebody). I drool over this every time I look at the catalog. As a kid, I never got the BIG Erector set with the electric motor and special parts.
Re: 80/20—it's the new black. Just add wood.
William Duffield
Interesting. If you need something very simple, it's a bit more expensive than Incra T-track, but there's a lot more versatility in 80/20's shapes. Unlike t-track, for building jigs, their extrusions can't be set in a half inch deep dado. They give external dimensions, but do not mention whether T-bolts or Festool 489570 Screw Clamps fit in the slots.
Re: I ♥ 80/20 for fixturing
William Duffield
Nice bench!
Thanks for the advice. I find that 80/20 have a distributor near me (25 miles, but in a direction I only go on weekends), so I could walk in with a pocket full of t-bolts and clamps and try them out.
If you think I have an overabundance of dog holes and holdfasts, you should see the plethora of Festool clamps and t-tracks in the power side of my shop, but kept mostly segregated from the hand tools.
Note that the Festool clamps fit in most standard size t-track, but not in the Kreg mini-t-track (which is low profile for installing in thinner sheet goods).
I'm currently considering installing the new Veritas prairie dogs in my Moxon vise jaws.
For those of you who don't understand the reference to the Swiss cheese, while I think I've posted pics of the Loxiliary bench here, I might not have posted pictures of the Moxon vise (used mostly for hand cut dovetails) that I subsequently attached to the front of the portable bench.
It is quickly removable for when I am not cutting and fitting dovetails. The bench also works superbly with a router, biscuit jointer or Domino. Unlike this inspirational appliance, mine is not easily tipped over when attached to a wide, stable base.
I have found that TransTint honey amber on rock maple does a pretty good job of imitating the cheese color.
Re: Cynomys ludovicianus
William Duffield
I'll bet they had as much fun inventing the name as inventing the dogs themselves.
I guess they couldn't call them Whack-a-Mole dogs, but I'll bet someone in the Rob's skunk works suggested it.
Alan Young
Great stuff- I've used for several contraptions on the day job:
and built a fluting jig for my router:
I like the look of the black but I wonder how well the anodized finished stands up to abuse??? You can also get this through McMaster Carr-maybe it's a knock off brand? I should say the regular finish-Not sure about the Black...
-Alan
Cheaper Alternative
Paul Vander Woude
A cheaper alternative can be found here:
http://us.misumi-ec.com/us/CategorySearchView/103_29000000.html
Not as pretty, but for jigs, tools. etc. this stuff could be handy. Under "Specialty Extrusions" they have some smaller 3-series extrusions that I have used. Just a couple of bucks for 6 foot lengths. The other series are larger, but still reasonably priced. Kind of like an Erector Set on steroids.
Re: There's no way you're not right.
William Duffield
I don't think that's very likely, but it would make a great story if it were so. My creativity, when it's working, doesn't work that way, at least not at the surface.
It's more likely that someone was playing around with one of those pop up glass door opener/closers from the hardware department and figured out how to adapt it to work holding.
Or for teeny-tiny furniture... *LINK*
John McGaw
...you might try MicroRax in silver or black.
http://www.microrax.com/
Roger Rayburn
William Duffield, Your Moxon Vice attachment to your bench fascinates me. Where can I go to learn more?
William Duffield
Well, I could give you a flippant answer and say, "Go to regional SAPFM meetings in the Mid-Atlantic area or to a CJWA meeting or a Woodworking Show in Somerset, NJ, or a Lie-Nielsen event at Hearne Hardwoods," where I've shown it, demonstrated it, answered all sorts of questions and had many photographs and measurements taken. Alack and alas, I've scheduled no more presentations, but will probably bring it to the Del-Val SAPFM booth at the the Hearne open house this fall (Oct 4 and 5) and to the Somerset show next February.
Of course, that won't do you any good if you're not in this part of the world.
The outstanding problem is that I need to write an article and process a bunch of construction photos, and publish it somewhere, but my literary muse needs to kick me in the backside, and I need to seriously shorten the HoneyDoList before I get started on it. In the meantime, what would you like to know about it? You can get the plans and lots of clues how to build one from Benchcrafted's website. Mine uses about $11 worth of 3/4-10 NC threaded rod and nuts from the Home Depot, instead of the greatly superior acme threaded hardware that Benchcrafted uses. Also, I turned the handles from bloodwood (for its density) instead of using the superior cast iron that Benchcrafted makes their handles from. The jaw is 8/4 hard maple. Mine has ~ 27" of clearance between the threaded rods. Its proper functionality depends strongly on mounting the front of the auxiliary bench flush with the front edge of the bench to which it is clamped. Otherwise the jaw racks vertically, because if the lack of height (1-3/4") of the rear "jaw". It therefore doesn't work very well for very short stock, unless you move it all the way to the right end, where it is supported agains the front leg.
If you ask more questions here, I'll be sure to answer them. I have lots of construction photos, if the Benchcrafted documentation is insufficient.
Roger Rayburn
William, I'm in Colorado, but thanks for the invitation. I was trying to figure out if it was attached to the jacks at each end of the vise or if you had it attached to some other (structural) member behind the jacks.
