wood grain filler
g clarke
I need to fill some pores in wenge and would like suggestions on what to use. What do you think of the following: Behlen Pore-O-Pac Paste Wood Grain Filler, Natural? Thanks in advance.
wood grain filler
g clarke
wood grain filler
Merle
I have never used that product. Normally Timbermate is the recommended filler. Hopefully, others will chime in.
http://www.amazon.com/s/?ie=UTF8&keywords=timbermate+wood+filler&tag=googhydr-20&index=aps&hvadid=4342937559&hvpos=1t1&hvexid=&hvnetw=g&hvrand=11984802762071529920&hvpone=&hvptwo=&hvqmt=e&ref=pd_sl_66492j1ulz_e
Re: wood grain filler
Jim Hoeller
I used a paste filler bought at Woodcraft many years ago for a red oak dining table. I don't recall the brand. I thinned it a bit with naptha and applied generously to the surface then removed the excess with burlap wiping across the grain. Wipe thouroughly under good lighting. Any residue will need to be sanded off and it dries hard as rock (or seems to). Next i added three coats of an oil based polyurethane. The result was decent and better than just stain and varnish.
John in NM
I've used a tinted version of Pore-O-Pac... my only complaint was with the tinting, stains the wood darker than I want.
I've also used pumice powder and a felt pad, I like the results a lot, but as you might expect it takes longer than grain filling pastes.
William Duffield
That's how I've used por-o-pac, and it works well.
You can color it with earth pigments, and I would recommend coloring it with something very dark for wenge, perhaps a mixture of burnt umber and vegetable black. In any case, to make sure the large filled pores are the color you want, with respect to the remainder of the wood, be sure to test your pigment mixtures on scrap, let them dry and put a coat of finish over the top. Lable your samples and keep notes. With the large pores of wenge, it is important to let the filler, especially if thinned with mineral spirits, to dry thoroughly before applying finish over the top. Drying time is less with naphtha, since it is more volatile.
I like Timbermate
William Duffield
One more tip: I usually apply it with a hard rubber squeegee to force it into the pores. If you can't fine one, an unbreakable switch plate will get the job done. If it does start to dry before you get it all rubbed off, applying a little more to the dried spots will usually loosen it enough to get it off. For a large surface, you will get a good workout.
JoeW Detroit, MI
I have used it on ash many years ago. It was colored black. If I remember right, I dyed the ash first and then applied a spit coat of shellac (1 lb cut) then used the pore filler. The shellac kept the black filler from coloring the dyed wood. The filler was applied with a plastic putty knife (throw away kind) and then wiped across the grain with burlap.
(Message Deleted by Poster)
Re: Pore-o-Pac head & shoulders above the rest...
William Duffield
If it's a small project, and you don't want to order a jar or two of powdered earth pigments, or can't abide the shipping time, you can use oil paints (from Michaels or A.C.Moore, e.g.). The linseed oil binder in the oil paint is completely compatible with the linseed oil binder in the Por-o-Pac., and so is the mineral spirits or naptha thinner or carrier.
I've bought from them...
John in NM
Nice to see they are still around
