What is it called?
What is it called?
What is it called?
Halinva
There is a type of (thick) adhesive that comes in a container resembling a test tube (except it is plastic). It is usually green colored. You break off a piece than squish it together to produce an adhesive-like substance. It's good for repairing pottery and rough surfaced material. (Including wood).
You help will be appreciated.
Hal Langerud
Re: What is it called?
David Barnett
(Message Deleted by Poster)
We call it plumbers putty but I don't
Know the brand. I know that it will stop a leak. I use it frequently when trying to duplicate small parts. It's easier than casting the putty in a mold of some kind.
Re: Epoxy putty
Halinva
Thanks, David. I "Googled" everything except "putty" before posting.
Hal
Jason Roehl in Lafayette, IN
Re: We call it plumbers putty but I don't
I've never heard it called plumber's putty. What I know as plumber's putty is just a soft putty that may dry out a bit over time, but doesn't cure or harden, and is used between a drain flange and a sink as a flexible sealant.
Jason
Same here....
John in NM
Great stuff, I still use it even when they provide some neoprene ring to use instead.
