Acclimating wood to shop
Merle
Last Thursday I bought some 2" qswo that was kiln dried and stored in a covered shed. My shop is 62* with a relative humidity of about 37%. I have the air cleaner running to keep the air circulating. How long should I let the wood acclimate before I start machining it for my project? I don't have a moisture meter and would prefer not to buy one if I can avoid it. TIA
Re: Acclimating wood to shop
Dick Coers
How long was it in the covered shed? If quite a while, it took back on a lot of moisture. Quarter sawn white oak is a really tough one to work with as well. It doesn't like giving up water without a fight, especially thick stock. I would let it sit at least 3 or 4 months, maybe longer. I wouldn't play around with wood stored like that without a moisture meter, it's really cheap insurance!
I'll lend you a meter...
John in NM
If I can find it.... I rarely use it anyhow, that is why it's in a box somewhere. Its a pin meter, that one Lee Valley sells. Once you get a feel for your shop climate, I bet you will find that you don't need to worry much about it - that's why I rarely use it.
One thing to consider, if they stored that wood any length of time in Gardner, it's probably already quite dry. They should have a similar climate to New Mexico, and the RH out here is great for keeping wood dry. When I lived in Tucson wood got down to where the meter wouldn't even register %MC during the spring/early summer. Just got that hot and dry. We don't have the same kind of hot, so it takes longer to dry, but I believe wood stored in the high desert should approach 4% after a few months.
Your wood may meter 9% now if its fresh off the train from where ever it was kilned. Wait until June and you'll see it won't register at all.
Thomas S Stockton
Merle,
I would not worry about it one bit and use it as soon as you want. If you are worried then cut into rough sizes for your project and let it sit stickered for a couple of days. if you have to resaw anything do it along with rough cutting. A board that is going to behave badly will move no matter how long you wait.
Tom
I usually let Oak I purchase from the local sawmill set for a couple weeks. Then I rough saw & plane near to size - if 2" I stack & sticker and let set for a week or two more before I final join and plane. Occasionally I find some I can't use due to bowing / curling or warp (rarely) and I usually have enough extra to make up for those, I use those for shorts etc. I have to agree though that some is going to move no matter what you do and other boards could be cut wet and only shrink across the grain! I do have a moisture meter as the sawmill kiln dries and stores in an unheated shed - in Indiana that can mean it picks up a lot of moisture when stored for long periods, especially in Summer. If the wood is near 10% I will use a much shorter schedule.
Well, we seem to have widely
Merle
divergent opinions. I just checked and the RH for Gardner is 18% so I am tempted to rough cut the one small piece I got and see how it behaves over the next few days. Thanks for the replies.
mark hennebury
Until it's done.
You don't need a moisture meter.
You need to observe the wood and see when it is ready.
You say that it was kiln dried and stored in a covered shed: This wont tell you what the state of the wood is when you brought it to your shop:
What was was it dried to?
Was it stickered in the shed?
Is it at equilibrium moisture content in the shed?
What was the Temperature/ humidity of the shed?
How does that compare to the temperature / humidity in your shop?
So if the wood was perfectly kiln dried and at equilibrium moisture content when it was put in the shed, if the environment of the shed was different than the kiln the wood will start to adapt to the environment of the shed, if it is stickered and with good airflow it will be a balanced all-round and equal stress on the wood until it reaches equilibrium with the shed environment.
Now you bring it into your shop, if that atmosphere is different it will have to adapt to that.
The first thing that you need to do is find out what state your wood is in:
To get an idea of the state of the wood when you bring it to your shop you can resaw a piece and note what happens:
1. if nothing happens then the wood has no moisture stress.
2. if it cups as you cut it depending on which way it cups you can determine if it is dryer on the inside or outside. The driest side will be the smallest and contracted the wettest side will be swollen and largest.
All this will tell you is what the current state of the lumber is when you receive it, not what its going to do.
To determine what it will do in your shop:
You need to find out if your shop is adding moisture, removing or neither.
If you take a piece of your wood and place it on a flat table surface ( preferable not a wooden surface) and watch what happens over the next few days;
1. if the wood edges cup up off the table the your shop is drier than the wood and will be drawing moisture from it.
2.if the edges cup down than your wood is drier than your shop and is soaking up moisture from the shop air.
Both of these conditions will create stress in your wood until your wood balances out with your shop and distort it especially when you start cutting it.
In short, nobody can tell you how long without knowing the exact state of the wood and your shop.
So test it, if its okay , use it, if not, sticker it and check it occasionally until its reasonably well behaved. I always dress lumber twice anyway, dress it first oversize and let it sit a while then redress it to final size.
Mark
Re: Well, we seem to have widely
Don Stephan
Keep in mind that the issue is not only will it misbehave during milling, but will it move excessively (perhaps while staying flat) after being in its final destination. QS wood more likely to stay pretty flat during milling, but if higher moisture content it may shrink more than anticipated after the furniture is finished and in a home or business. So a panel may show daylight in its frame, or a door may have unbalanced gaps along sides and top/bottom, and so on. Moisture meter is a good tool for the workshop.
good advice, but......
Bill Tindall, E.TN.
....there are all sorts of things you can begin to do whether it is acclimated or not. Frankly, I never worry about it nor did any of our professional customers when we sold KD lumber from a shed. I (and they)just get on with building.
I did worry about how the lumber, and parts sawed from the lumber, was stored in the shop (with free air circulation all around). But there is little you can't do so long as the moisture content is not absurdly high, like over 12%.
I recently finished a large work bench for son in law. I had the top sitting on my bench with small spacers as the humidity indoors began to drop. The top cupped 1/4" so I put larger spacers under it to provide better circulation and in a week it straightened back out again.
Thanks for all the responses!
Merle
Since Bill and Tommy agree, I think I will start ripping the stock tomorrow AM. :)
Re: Thanks for all the responses!
Jesse Cloud
Hey Merle,
Good advice above. One item I would add is that moisture content is really important when you are mixing old stock with new. If all the stock has been in the same environment for a while, it will grow and shrink together. If not, what will happen is less predictable, the old may grow while the new may shrink or vice versa. That's when a meter is helpful.
If you will be using just the new stock on your project, just plan for some movement in both directions.
Probably way too late, but I'll be back next week and would be happy to loan you a meter.
Merle
Thanks, Jess, but it will all be made with the lumber I got from CSWoods last Thursday. I have kept a fan running and have stickered the pieces that I have started machining. So far, everything has performed very well. :) Enjoy your vacation.
