Veneer Glue
Veneer Glue
Bart Goldberg
Veneer Glue
Bart Goldberg
In the past, I have always used Unibond 800 Veneer glue. I need to replace the Unibond I have as its way past its self life and now looks kinda funky in the container. So, I'm curious if the Franklin Cold Press Glue is decent as a replacement. FYI - I used a vacuum press and typically do small, flat projects, and not large bent laminations.
Thanks
Bart
Re: Veneer Glue
Re: Veneer Glue
Thomas S Stockton
Bart
Never liked the titebond. The two glues I really like are fromm www.pro-glue.com, the high performance pva is my go to glue and for marquetry and bending I use his low formaldehyde resin glue which is similar to glues like weldwood. I have not had problems with resin glue staining maple and cherry green like unibond can do.
Tom
Re: Veneer Glue
Re: Veneer Glue
Don Stephan
You're talking about two entirely different types of glue. My preference has always been for urea formaldehyde glue for veneer panels, whether marquetry or simple leaves of veneer. If you want to switch to PVA type you might consider making a test panel of the largest size you're likely to glue, to gain experience. The water in PVA types may make the veneer buckle more than you're used to with UF adhesives, especially if you ever make a veneer two ply with marquetry panels.
Re: Veneer Glue
white works for me
Bill Tindall, E.TN.
and that is what is used in the Mack Headley And Sons shop and it or yellow is what Steve Latta used in our class. For ordinary panel veneering no special glue is needed.
Re: Veneer Glue
Re: Veneer Glue
Tony - Memphis
For me, it depends on what I am making. I just did an 8"x30" panel last weekend and used liquid hide glue (had some handy thta was getting old). For small panels with hidden edges, about anything will work (even polyurethane glue). Anytime I have seams, I use the Unibond out of fear that things could open up. I've also been experimenting with the new PVA glues sold by Vacupress and Joe Woodworker. My understanding is that that they do not exhibit as much creep. Unibond gets expensive, especially when I throw most of it out. The Joe Woodworker glue seems pretty good. I even tried soaking it after it cured and it didn't budge. It does not bleed much either (I believe it has a pecan or walnut shell filler). I was considering using it on my last table top, but I went with a known because I had way too much work in it to experiment.
I have found lots of good info at Vacupress and Joe Woodworker.
Tony
Re: Veneer Glue
Re: Veneer Glue
pecker
I regularly use the Cold Press glue you are considering on panels up to about 18" x 48" in a homebrew vacuum press. It works just fine, though I don't do marquetry or complicated patterns with a lot of seams.
It applies best with an adhesive roller cover on a paint roller, rather than a brush.
It also has a shelf life, but Ive kept open jugs of it for 2 years or so.
Re: Veneer Glue
Bob
Re: Veneer Glue *LINK*
Bob
Bart, Try "Old Brown Glue" Good for what your doing and it has an 18 month shelf life.
http://www.oldbrownglue.com/
Re: Veneer Glue
Re: Veneer Glue
Jesse Cloud
I've used Unibond, hide glue, white glue, yellow glue, and probably some others. They have all worked. Only caution I would give is that the PVA glues have a much shorter open time than the urea formaldehydes, probably not a big deal if you are doing fairly small pieces.
