OT - laptop help - fan problems?
I bought a laptop lap chill mat - a fan equipped stand for a laptop.
I bought it because I was somewhat worried about my laptop fan.
How can you tell if a laptop fan is malfunctioning? I have downloaded a manual and it does show how to replace the fan (presuming I can find one). I am going to try and clean the laptop fan and all of the vents first. One of our previous cats liked to lay in our laps when we used the laptop and warm himself on the laptop (and our laps) - so I am presuming that fur may be clogging the works.
I've download a temperature program - and I'm quite surprised at how warm the CPU and internals happen to be. I wasn't really aware that there were temperature sensors (or the equivalent) inside our laptop. The fan does seem to be making noise - and the bottom of the laptop is warm.
Re: OT - laptop help - fan problems?
Jason Roehl in Lafayette, IN
Cleaning can make a huge difference. Try it and see. Use the canned air.
As for the internal temperature, I'm not 100% certain, but I think it's not a sensor but a calculation based on the processor's monitoring of its own power usage or something like that.
I just had some other issues with my laptop, and in the process, cleaned out the fan, vent holes, and the heatsinks, and I went from hearing the fan from time to time to not hearing it at all (which I had forgotten was how it was when it was new).
Jason
Bill Howatt
All modern processors have a sensors built into them and in the multi-core processors there is one for each core. In the old days I think some of the AMD processors had a sensor in the open part of the socket under the CPU.
Bill
Lars Parrington
if your fan dies, your laptop will probably stop working, or only work for a few minutes at a time until it overheats. however, it is unlikely that a dying or dead fan will cause any permanent damage.
your processor can handle surprisingly high temperatures. the cpu in my laptop will reach 90 celcius under full load, and that is normal. also, your laptop probably has some built-in low-level software that will cause it to automatically shut off if the cpu gets too hot, before any damage is done.
it should be relatively easy to find a replacement fan from some online source. as long as you have some small screwdrivers, swapping it out should also be easy. if you're feeling nervous about it, look for dissasembly instructions for your laptop online, maybe there's a service manual or a youtube video.
