My house was built in 1966 on a crawlspace. Lately, I have noticed the wood molding separating from the ceiling in my family room as well as one of my kitchen cabinets drooping from the ceiling. I went into the attic and noticed light from the family room. I could slip a piece of paper through the attic ceiling into my family room. Is this normal settling of the house or a foundation problem? I live in Virginia. I keep the heat on high and it is cold in the mornings and evenings. Should I be concerned? What do I need to do?
I'm not sure I understand how there could be a gap to the attic? But, I live in a newer house where the sheet rock meets in the corners and there is a double plate of 2x4's at the top of each wall. Your construction might be very different. My molding expands and contracts with the seasons and pulls away from the ceiling in the winter when it is very dry.
Have you noticed any issues with windows or doors opening/closing? Any cracks in the sheet rock or plaster? I would think there would be other signs of settling. Also, if you didn't have to dig through insulation to see the light coming through, you need to seal the gaps and add more insulation.
Yes, the sheetrock/drywall which makes up the ceiling attaches to the 2x4s which I can see in the attic. The drywall/sheetrock has separated enough to slip a piece of paper through and I can see light. Should I cover this gap with insulation? I have the pink rolls--not the blowing type. Would that take care of any problems or is it more serious??
I hesitate to comment on what the issue might be without seeing it and being better informed. Plus, I'm no expert. If you are concerned, find a home inspector you can trust and have them take a look. Might be worth it for piece of mind. Our old house had one door that became almost too hard to open in the winter and a crack formed above it inthe drywall (we were on a slab). Come spring, all was well. Never did figure out exactly what/why and it is probably still that way! Yours could just be typical settlign/poor construction/seasonal etc. Hope its nothing serious. If it is consistent around the room and there are no other symptoms, you are probbaly ok.
Any good quality latex caulk would be a good choice for the gaps assuming they are small. Typically, a painter will apply a small amount of caulk at the molding/ceiling or wall joint to close it up before painting. Important to use paintable caulk and caulk that is meant for that application (there are lots of caulks out there these days). I would fill the gap from the attic side for sure to block air flow. If you fill the gap at the molding, you may have to touch it up with paint afterwards (more work). As for the insulation, just make sure everything is covered well and the insualtion is nice and luffy. You can always buy a roll and replace areas that have been matted down or don't quite cover well (buy the same type and pay attention to the backing or lack of backing). Filling those gaps may help with your heating and cooling - air flow is the enemy here. Be careful up there! Be careful where you step too!...don't ask my how I know to remind you!
Thank you so much. I feel a bit better. I felt like my house was sinking and I've have to pay $20,000.00 for those foundation pilings! I do have a painter that we use so I will call him and see what he says. Thanks again.
Are there cracks in the sheet rock - or just signs of separation?
You are losing valuable heat through these cracks. It may be that the builder neglected to put corner bead between the walls and the ceiling. Many builders don't - they just put inside and outside corner bead on the walls. They usually used the ceiling texture to cover up the cracks between the wall.
My personal fix is a corner beading tool and a LOT of caulk. If you have a textured ceiling - this might be somewhat problematic. In that case when you cut the tip off of the caulk tube, just cut it small and caulk directly into the corner. If you don't have a textured ceiling - it is easy.
Another alternative is crown molding. That's what is often used.
At any rate - insulate. Make sure that the insulation is up tight against the ceiling joists.
Thank you. There are no cracks in the drywall - just separation about 1/8 of an inch from the ceiling but enough for me to notice since my wood molding is painted walnut color.
The crown is not drooping away from the ceiling, it is shrinking due to drying out to a lower moisture content than when it was installed. Having your heat on high during these cold months dries wood out lower than normal times.
If you can't fill the cracks from above, you might want to remove the crown, then caulk between wall and ceiling, then replace the crown. But, besides fiberglass or caulk from above, expanding foam may be another option.
However, I don't recall ever being in a home with a living room, which didn't have at least one outside wall, which would be really hard to fix from above, so removing the crown to seal behind it, then replacing it probably would be the way to go.
Being a Home Inspector, I appreciate all those who recommended one. I am in the Richmond Va area and perhaps I know one you might use if you decide to go that route. Do be careful, not all Home Inspectors are created equal and there are many I would be skeptical of.
For your own satisfaction, you can walk around the outside of your house and look at the foundation. If it has settled, you may be able to see the cracks. Look around foundation vents and near corners. If the house was poorly constructed and it was built in 1966 you should see cracks by now. If you don't, that is probably nor the problem.
How long have you lived in the house? There are some types of cracks that "cycle" with the seasons. Do you have trusses or conventional framing. There is a phenomenon with trusses known as "truss lift" or truss up lift". If the bottom cords of the trusses were made of juvenile wood. they can contract in winter, causing the trusses to arch or lift up in the middle of the house. This can also happen with individual pieces of lumber. Basically they warp in winter and "unwarp" in summer. So think about it. Does the problem come and go?
If the gaps are small and particularly if they are stable, the caulk is a good idea. Once a house is reasonably well insulated the principle source of heat loos is infiltration/air loss. Warm air rises out through the ceiling, drawing cold air in behind it.
From the fact you could see the gap from the attic and did not mention digging through the insulation, I suspect your house has the same insulation it had when built. If you are lucky, that might be R-19. Since then the local standard has gone to R-30 and now it is at R-38 and headed for R-49. You should give some thought to increasing the insulation dramatically. I personally like blown in cellulose. Its in expensive, made from recycled paper, more dense that fiberglass and thus slightly more resistant to air flow. (Insulation basically acts like a filter when confronted with moving air. With a good flashlight you might see dirty patches of insulation in the attic, a clue to moving air.)
If you have the patience you might do yourself a lot of good by going into the attic and sealing every hole that penetrates the drywall with caulk or foam like Great Stuff. Around every pipe and duct and light fixture and into every hole for wires. A tedious and ugly job but not expensive. $50 worth of foam and caulk. Then have the insulation blown in. I would pay a pro to do the insulation. Their buying power is much greater than yours and you should be able to find somebody that will do it for very little more than you can buy it.
You can also seal up outlets with gaskets under the cover plates and some of the holes through the floor. On a windy day, you might be able to use a "smoke pencil" to find leaks. Since smoke pencils are somewhat hard to come by, a cigaret will work. Anything that put out a little stream of smoke. Hold it near the suspected hole and see which way the smoke goes. If it is disturbed, air is moving. I found the gaskets cheap if you are interested let me know.
I can go on and on, but I won't unless you care and are willing to take a shot.
Do be careful in the attic. Way too easy to make a misstep and fall through.
Karen, I'm reacting to your very first comment about keeping the heat on high and it is cold in the morning and the evening. Houses built in the 1960's had insulation, but nothing like today. The cost of heating is going to get more expensive, not less. I concur with the suggestion to talk to a Home Inspector, and I would add that if I were in your shoes I would select one that has the tools and experience to do an energy audit. I have a feeling that if you correct the cold in the morning and evening problem you will pay for the Home Inspectors time very quickly.
I'm guessing trusses for your roof? Have you changed heat type lately? Gone to a better SEER heat pump? Added gas logs or something to that effect? Increased wood heat? My crown/ceiling does this every year. Hard to eliminate with trusses. It'll close back up in the summer.........
It sounds like the molding is covering the corner of the walls & the ceiling, much easier & cheaper than spackling the joint.
To check for level you can rent or borrow a good quality laser level, no something from home depot or lowes, & check the floor & walls for level & plumb. Get a 4' level & check the doors & windows for level & plumb. If things are all OK levelwise it's probably settlement. Remove the molding & spackle the joints that are open.
I lived in an apartment that had small cheap crown molding in all the corners & one winter I was sitting at my desk across the room from the windows & would hear the wind rattle the glass & then 15 seconds later a frigid breeze would pass over my desk. The air was blowing down from the attic above. I used sprayfoam to seal the worst, caulk on the rest, & replaced the crown.
