Treating a large pine standing Pine stump?
Keith Newton
I'll be meeting with a prospective client who wants me to sculpt something from what remains of a standing SYP in her yard. I think it may have been stripped of its limbs by the ice and snow Dec 26th.
Do any of you know if there is a way to treat a standing snag to resist insects and decay after it is finished?
The location is AR.
Re: Treating a large pine standing Pine stump?
Bora Care is one of the least toxic alternatives. Works against termites, powderpost beetles and other insects. Should be good against fungus. Available on-line. Just do a search. I've used it to treat air-dried wood.
You'll probably have to have a finish of some sort on top of that.
root rot
Bill Tindall, E.TN.
When a long leaf pine dies in the woods in TN it falls over within a couple of years because it roots rot away. Don't know any way to retard this event.
Re: root rot-a possible solution
Tom Dunlap
That's a very good point. The soil is filled with rougish fungiis that turn plant life into soil.
It's possible to make a smooth, level cut at about ground level to separate the trunk from the stump. Re-setting the trunk on some blocks of treated wood, plastic or some such creative solution will make a physical barrier from the soil/stump.
There is a mixture of borax and anti-freeze that wooden boat restorers use to stop decay that might be used here. Google should help find the mix.
Tom
