Any body got advice on working acrylic?
My son is getting back into aquariums and has decided to build one out of acrylic. He has been reading on it on various forums. Today he bought some remnants from a local plastic shop. (I am trying to stay out of this) Tonight he tried to rip some with my Frued Glue Line rip blade. That did not work well. It appears the blade set up a harmonic and he got a rippled edge. He needs a very straight clean edge that you clamp into position ans then "wick" the glue into the joints. I put my Forrest WWII blade on the saw and it did much better, even though we were only removing about half the width of the blade.
The shop was cold because the saw faces the garage door and he had it open to allow or a long out feed. (Small shop blues) Wondering if this stuff is temperature sensitive.
So, anybody got advice on how to generate long clean straight edges? (I have a TS and a jointer with standard steel knives, a Makita hand power plane, routers, and a hammer.)
Re: Any body got advice on working acrylic?
walta
The best bet is to buy the blade made to cut plastic.
The more teeth the blade has the better my luck.
Next violate the safety rules raise the blade to its full height. This reduces the chipping and keeps the blade cooler.
Walta
Dick Coers
I prefer to cut oversize on the table saw, the take off a 1/16" with a router. I use an Onsrud O flute bit and it cuts it like butter. They now have a super O flute, haven't used one yet. I use the 2 straight flute, but the also have spirals. No chip out, smooooooooth cut. Did he pick up polycarbonate, or acrylic? Used or drop off acrylic has to be used carefully. Any deep scratches will act just like a scratch in glass. It will snap. I've never made an aquarium, but I was thinking they used silicone for the joint. Maybe that is just glass.
Keith Newton
If you have a table router, I would make fence with an offset like your jointer. In fact, you can use your jointer to make it, just by feeding a board half way in, taking a bout 1/16" depth.
Then cut an opening for the bit in the middle of the step. I like using larger router bits ~ 1" diameter. Set the fence where the outfeed end is in line with the OD of the bit, so it doesn't leave any end snipe.
Back to the saw. Never use a blade which isn't really sharp, nor has any wood pitch on the side of the teeth. Feeding too slow, even with a good blade will lead to melting. Of course dull blade, fence misalignment will too. But feeding too fast will produce chipping, so finding the right feed rate helps. You can also spray the blade with a lube before each cut, if you can't work the other tricks out.
Besides getting a perfect cut, setting up the parts for the methylene chloride bonding method is a pretty tricky task in itself, so I hope you or he have had some instructions. There are some two part adhesives which are easier to get a perfectly clear line, but they are really expensive.
I ran a plastics production shop for about a year, and still do some plastic work on a fairly regular basis now, about 20 something years later.
Don Evans
There are special glues for plastic that you wick into the joint between too pieces methy something or other. I have some of it and did not have much luck with it being very strong. Of course that has a lot to do with the thickness of the plastic, mine was just 1/16" thick. You are right, the joints much be perfectly straight and smooth. If using a table saw blade you need one with 3 deg negative rack on the teeth. A regular wood cutting blade will never do the job good enough.
I don't think you are going to have any luck with this unless you have plastic angle also glued to each joint, the water pressure will bust it if you plan to only count of the joint alone to hold it together.
Also this glue that is used has the same viscosity as water literally. You'll need a special bottle with a very small spout on it. I'm trying to remember who sells all this as they have the bottles to use to apply but I cannot remember at the moment.
This maybe the site I got the glue from, one more caveat: There are 2 types, one for acrylic and another for poly. You MUST have the right one for the type material.
These folks do sell corner angles and syringe: http://www.usplastic.com/catalog/item.aspx?itemid=83722&catid=560&clickid=searchresults
Don
Rick W
Here is is a link to the Plexiglass fabriction manual: http://plexiglasssheets.info/howto/fabricationmanuals.htm, which explains things better than I can.
As far as the edges go, just run them over the jointer, taking a 1/32" cut and moving about 1 inch a second.
Rick W
Al Goldstein
Barry, Don is right. You need extra support for the butt joints. All plastics, except Teflon, will absorb a bit of water over time. The slight expansion of the inside surfaces can cause the butt joint to fail. This is quite similar to joint failure that can occur when veneer is only applied to one surface.
I used to make acrylic water tanks out of 3/8 inch stock. For years I filled the tank, did my work then emptied the tank. Then I got enough lab space to keep a tank filled with water. One day a butt joint on this tank failed with a loud crack and the water all spilled to the floor.
Others who did the same work as I made acrylic tanks out of inch thick acrylic to avoid this problem. I finally developed a technique for adding acrylic dowels to the joint to avoid the joint failure.
I always found that the people at the plastic shops were happy to give good advice. That is the way to go.
Good luck.
Do up the top button of your shirt
GolfSteve in Calgary
Or the chips from the table saw/router fly down your shirt and end up in your underwear.
Doesn't seem to happen when I cut wood but always happens when I cut plastic.
