OT - joining a pipe w/o couplings? For theater
Need to join several pieces of 3/4" or 1" pipe to act as the bottom weight for a drop. I don't want to use couplers as they would leave a "knuckle" in the pipe sleeve.
I've thought about putting in dowels (either turned by me or commercial) and then some wood screws through the metal into the wood. I also thought about finding a tap and using all-thread. Any other thoughts?
TIA.
Re: OT - joining a pipe w/o couplings? For theater
john Veerkamp
If you use a dowel(my suggestion) be sure to file off the burr inside the pipe. Otherwise your dowel joint will be floppy. You might be able to use EMT as a sleeve that wouldn't show too much.
How long?
My local contractor's lumberyard sells all-thread in six foot lengths. If that's within your length range, you could just stack up your pipe on a length of all-thread and put washers and nuts on each end.
Re: How long?
Forty feet. If I use all-thread, I'll tap the inside of the pipe to the correct diameter - if the pipe is thick enough.
RogerInColorado
Seems to me I've seen couplings that mounted internally to pipe for use in making pipe clamps longer. I think I've only seen them for 3/4 inch pipe. I should correct myself here. I haven't seen them physically, only ads for them. Have no Idea how far beyond the OD of the pipe they extend, but can't imagine they would extend far, if at all.
How about the pipe used as top rail on chain link fence? One end of it is swagged down and fits inside the pipe. They have it at Lowe's and HD in at least two diameters and several lengths I think. Also and fence company would have it too. Its cheaper than galvanized water pipe and somewhat lighter in weight. Heavier than EMT.
Joseph Mulherin, sr
I was going to suggest the same thing Barry. But, the pipe is 1 3/8" dia. but loghter than 1" pipe.
john Veerkamp
Another thought, using the fence rail as suggested get black iron pipe sized to slip inside the rail pipe. Make both pipes full length offsetting the joints by half. You can get both types of pipe in 20 ft lengths. Easily assembled and dis-assembled.
I agree w/John-EASY
Dowel
John in NM
I had to do that with some 1/2" pipe, needed to make a cheater for a huge lug wrench and a bit of 1/2" steel rod fit right in. With the seam in the pipe and the burr from cutting it, the rod was a tight fit and needed no further attachment. You may not get that lucky, but then you may not want an interference fit anyhow, being in theater it will have to come apart again at the end of the run.
