OT - running a gas line
I'm running a line for a little gas heater. I haven't looked up the demand yet, but the similarly sized heater in our living room only requires 1/2" pipe for the eight foot run from the main supply pipe.
However, this heater is on the far side of our (1500-square-foot) house from the gas meter. Rather than calculating the distance from the meter* and the pipe size requirements, I'm running 3/4" pipe, the size of the incoming pipe from the meter, from the point at which I tapped the existing lines.
But I'm thinking that, if the gas demand for the new heater supports it, I may drop down to 1/2" for the last, short bit through the wall and into the room. It gives me more flexibility in selecting a gas valve. Is there any reason that I should stay with 3/4" all the way to the valve?
*Like most older houses, the gas lines under the house are not exactly rationally laid out; there's a certain amount of wiggle and wander as they make their way around.
