OT Anybody a real lighting cost Expert?
Local news just ran a story about waste at city hall. They leave the lights on all the time. Building looks like a bad Christmas Tree even on Sunday when no body is there. Turns out the building was built with a flexible floor pan that allows walls to be easily moved around and as a result, there are very few light switches. The claim was that the electric bill is about a million bucks a year.
Its a dim recollection, but I took a course on this stuff in college, back when you had to outrun dinosaurs to get to class. As I recall, the argument was that fluorescent lights suffer from being turned on and off and it basically cuts bulb life in half. So, if you turn them off 12 hours a day, they last about as many days as if they were left on all the time. That means you still have to replace the bulbs just as often and you do not double their apparent life. If you factor in the cost of the switches it might save enough to run the lights a long time. Another consideration was something called power factor. In buildings with three phase power you can run the lights, using them to absorb or adjust the current between the phases, (or some such mumbo jumbo) effectively running them for free. We were told that the reason they put light switches into commercial buildings was the public would not believe it actually was more effective to just let them run.
(I suspect they are on a campaign to install switches and turn out the lights and will find they have spent a fortune and save very little. It might also be the problem that the building basically has a glass exterior which means we can see them wasting light, but the heat bill might be the real problem.)
So whats the real truth here? Anybody know or know where to get a real answer?
