Craftsman TS arbor bearing replacement
Doug in Utah
I have an old, belt-driven Craftsman table saw (113.29940) from the sixties. While trying to align the blade I discovered that the arbor bearings are shot.
I'm wondering how difficult would it be to replace them? Is it a DIY job or are special tools required?
Here's hoping that someone here has done this and can give me some first-hand advice.
Re: Craftsman TS arbor bearing replacement
You might wander over to Old Woodworking Machines *LINK*
and ask this question there, too. Believe me, you'll get plenty of advice.
And, if you also register at the sister site, Vintage Machines, you can get access to owner's manuals, parts lists, etc. I find exploded parts drawings a godsend when I'm doing machine disassembly. There's a link up at the top right of the forum directories at Old Woodworking Machines that will take you there; it's titled "owwm.com links," the old URL for Vintage Machines.
Read the rules after you register. They're all sensible, just slightly different from many places.
Linky below.
http://owwm.org
Ralph Lipeles
I just looked at a parts diagram for a 299142 which I expect is similar. There is a bearing on the arbor that sits in a casting and is retained by a plate held in place by 3 screws. It looks very straight forward to me.
Ralph Lipeles
Pete in Holland, MI
Pop it apart if you're confident doing so. The bearings are usually pretty common in saws like that. An internet search will probably find several places to buy them on line, or take them to your local power transmission store and they can order them up.
As you re-assemble them, often there is a pre-load nut on the arbor. Make sure not to overtighten this nut, else the bearings will prematurely fail.
Pete
