Re: Skil HD77?
Robby Wright in San Marcos, CA
Charles - I have owned a Skil 77 wormdrive saw for over 40 years. I'm on my third one now - the first two I was given by my father and grandfather. Both had been dropped without much more damage than a chipped casting or bent shoe. The 77 is a brutal powerful saw, but is capable of fine work as well. It is heavy - that wormdrive transmission weighs something, but it doesn't stall easily in wet wood and will keep cutting all day long. Get a rafter hook to replace the top handle and you will be able to hook it over framing lumber when you are up high.
There are two things I love about the 77. First, the blade is on the left side of the saw. I hold my saw in the right hand and having the blade on the left makes it easier to see where I am cutting. Second, having the handle in-line with the blade makes it easier to steer. Add a decent carbide blade and you have a very good saw.
The advice to also look into a chop saw or sliding compound miter saw is good advice. You will tend to cut many pieces to length before you assemble them and the chop saw on a proper stand can speed that up.
Good luck with your new career.
