Painted boards in jointer/planer
Joe in a Cleveland suburb
How stupid would it be for me to put about 4 boards (about 3/4"x4"x4') that have latex paint on them thru my planer and jointer?
Both are due for new blades anyway.
Thanks in advance.
Re: Painted boards in jointer/planer
Not stupid at all
Dustmaker Mike
I have done it a lot making signs I carve out the letters then paint the entire sign. I then pass it though my planer to clean off just the top. Works great.
an alternative view
Bill Tindall, E.TN.
Paint is loaded with titanium dioxide which is highly abrasive. If the knife is traveling from within the board and then through the surface paint, abrasion will be minimized. This would be the case with paint only on the surface. However, if paint is on the edge, the knife will be traveling into the paint and I predict the paint on the edge will abrade a substantial groove into the knife.
Consider the cost and aggravation of sharpening knives and the cost of the lumber salvaged and then make the decision.
A wire brush on an angle grinder is effective for removing stufff on the surface of lumber.
JMOHNIKE
If you have one use a hand plane first. Some times I find a nail or some other metal object. Easier to remove a nick from a hand plane blade than joiner blades.
Norm Knoxville
Joe, I suggest you hit it with a coarse grit belt sander and then run them through your planner. Norm
Robert Hayward
That is what I do with painted boards I want to reuse.
Bob
