uses for contact cement?
Jerry Gibbs
I have most of a pint of contact cement left. Are there practical uses for the glue other than laminates etc.? Jerry
Jerry Gibbs
Re: uses for contact cement?
William Duffield
Attaching veneer (wood, not pictures of wood on plastic) to plywood or solid wood or termite barf substrate.
Attaching leather to vise jaws, etc.
Attaching paper patterns to plywood templates. For this purpose, I prefer 3M spray adhesive, which is a contact cement, but easier to apply than the liquid variety.
Put it in a paper bag and sniff it.
(The message here is to always use a respirator with a VOC filter when you are using it, unless you want to rot your brain.)
Damn!!!
"Put it in a paper bag and sniff it.
(The message here is to always use a respirator with a VOC filter when you are using it, unless you want to rot your brain.) "
NOW he tells me?!!!
actually--
McKay
Wood veneer will "creep" using anything other than a ridged line glue like liquid hide (Old Brown Glue, etc) or resin glue (unibond 800 etc). I would hate to put in hour upon hour of work on a marquetry project just to have it ruined by using titebond or contact cement.
Bad day to give up contact cement
Re: actually--
paul in AZ
I don't know about that. I've used contact cement for veneer -never marquetry though. The real stuff and not the paper backed crap. As to durability without trouble the longest is over 30 years. Maybe I've been lucky.
I'm with McKay,
Dick Coers
contact cement is for high pressure laminate, not furniture grade veneer work.
had to show id to buy the fumy stuff
Ditto
Don Stephan
Wouldn't use contact cement for anything other than high pressure laminate - Formica, Wilsonart and the like. Once saw a bubble more than 12" in diameter under wood veneer on the end panel of run of kitchen cabinets less than six months old. The end panel got full morning sun which must have warmed and softened the contact cement underneath. Because high pressure laminates are very stiff they can't form bubbles and sag.
Re: Ditto
rogerincolorado
The best thing do with leftover contact cement if you don't use it on a regular basis is to put the date on it so you know when to discard it.
Modern art?
Jerry Nicholson
It makes interesting patterns when you accidentally string it out on carpeted basement stairs.
Jerry
