How Do I Transport Sheets On My Roof Rack?
Derek Arita
I have an Exterra with a good roof rack that has cross bars. I know there must be a way to safely carry sheet goods up there, but I'm getting a headache trying to figure it out. Anyone have any solutions?
Re: How Do I Transport Sheets On My Roof Rack?
Bob Entwisle in NJ
Load it up, tie it down, tie it down good, drive carefully, maybe slower than you might normally, pay attention, haul it home.
Depending on how flexible the sheet good are you might add a couple of 2x4's underneath the sheets for support.
Bob in NJ
Re: How Do I Transport Sheets On My Roof Rack? *LINK*
Tom Dunlap
If you buy your sheet goods from the Borg you MUST use the Bork Knot to tie the stuff to your rack. The Bork Knot is very easy to tie...here's how:
If you don't know a knot,
Tie alot.
I wouldn't trust the synthetic twine that is at the door to tie down much. Then again, I have lots of short ropes around since I'm an arborist.
Get some long ratchet straps. Not the cheapest ones either. Go around the sheet goods and your racks from side to side and front to back.
It's not a bad idea to stop after a mile or so and recheck ratchet tension.
Tom
Truckers Hitch-a freebie to tension tie downs
Rent or buy a trailer....
or at least give it serious consideration. Even one of the folding 4 x 8 trailers may be worth considering. You won't have sheet goods acting as a sail that way.
I've got a Subaru Forester. I use my rack all the time to transport long boards (1 x 4 x 12', 1 x 4 x 10', etc.). I tie lots of knots!
I don't use my Forester to transport sheet goods - I'd rather not chance lifting 3/4" plywood that high - it would strain the muscles and the vehicle too much..
Be very careful
Lee Schierer McKean, PA
Your roof rack is only mounted into sheet metal and is not very substantial. If you check your owners manual it will likely limit the weight to less than 100-150 pounds. A single sheet of 3/4" plywood may be all it can haul and stay within the rated load.
As far as driving with sheet goods on your roof. Remember that the air flow up over the hood is going to try to lift the sheet goods, so you will want a couple of tie downs over the sheet and down to the front bumper or tie down points on the vehicle. (Ever try to walk in a 5 mph wind with a sheet of plywood? Think of the wind force at 20 mph) Use a good 3/8 or larger nylon rope. The twine provided by the Borgs or the lumber yard won't hold much. Then drive home very slowly. Remember if your sheet goods take off and cause an accident you are liable.
I would much prefer to haul sheet goods on a trailer or inside the vehicle.
Lee
Re: Be very careful
Nat Robison
For my money, I'd much rather get the rental truck from HD or Lowe's if you can get your errand done in 75 minutes. If no HD or Lowe's nearby, then it's not as easy and I believe HD near me is now insisting you buy something there in order for you to be able to rent the truck.
I've also rented a van from U-Haul for a few hours....relatively inexpensive and full sheets could lay flat on the floor of their Ford vans.
Re: Another thought - Lumber Yards Deliver
Bob Entwisle in NJ
After reading several posts suggesting renting a truck or trailer,
How about a local 'real' lumber yard? They deliver. (they also load it on their truck, and unload it at your house).
Add the cost of renting a vehicle, the hassle of loading and unloading the material, and you might find you're not saving anything at all hauling this stuff yourself.
Bob in NJ
I don't recommend this   *LINK*
http://cellar.org/iotd.php?threadid=472
We call it a Canoe knot for tying down canoes
Look into a trailer...
John in NM
Even a small one might work better than using your roof rack.
Either way, some ratchet straps are a handy thing to keep in the car - they might bend up the roof rack though.
Speaking of real lumber yards...
Meyers out of Soddy-Daisy, TN. Makes two runs a week to our area.
Yes, there is a minimum - and you pay a fuel charge. Delivery cost is minimal - ends up being about $40 - which isn't bad.
North GA Hardwoods - there is a minimum and a delivery charge, about $30.
In one case it is ~70-80 miles round trip for me at 10 miles per gallon so call it ~ $30. In the other case it is about 220 miles - so call it $78. So you figure on a days worth of time either way.
If I need to pick lumber - I usually go to North GA. I can load it on or in my Forester. I like picking lumber.
If I need sheet goods - I have them deliver - much cheaper I can order 4 sheets of 3/4 VC shop grade maple (or whatever) and have it by Friday.
Re: Look into a trailer...
Derek Arita
Yeah...I gave it more thought and figured out that it's not a very good Idea. Thanks for all your feedback. Since I sold my Expedition, I've been renting a truck from HD when I need to transport sheet goods. I'm just getting tired of spending an extra $30, while buying the cheapest sheet goods I can find...doesn't make sense to me.
The folding trailer might be the way...just have to convince the wife that I can store it, without it getting in her way...she's a real ball buster and barely lets me have my machines in the 2-car garage/shop, along with her car!
Get it rough cut
Al Goldstein
Most borgs will make several rough cuts on a 4 X 8 sheet for free.
Make a cut list of the pieces you will need. Then make a diagram of the 4 X 8 sheet with the pieces (oversized) placed to get the sheet cut down to a size that will fit in your car. 3 X 4 sheets can easily fit on the floor before the back seat of most cars. Some trunks are large enough for storage as well.
I almost always have the sheets cut down to fit before my back seat. Besides being the safest way to transport them they are easy to load and unload and the weight of all the sheets is distributed fairly evenly over front and back wheels.
Even if you have to pay extra for the rough cuts, it is a small price to pay for a safe trip home.
My garage has maybe 1000 board ft. stacked on one side and the lawn mowers and other stuff on the other side.
Be firm - take back part of the garage!!
Good idea...
John in NM
I'd forgotten that one, but I've cut up stuff in the parking lot more than once. These days with decent cordless saws it's even easier. My regular yard in Albuquerque let me plug in a cord near one of the roll up doors when I bought the 18' Lyptus planks :D
Gary Smyth
In November, 2012 an inquiry was made concerning wind force but dealing with a sailing question. The site is: http://www.daysailer.org/forum/viewtopic.php?f=8&t=4233 If interested I urge you to look deeper there.
I used the postings from that site to relay here a ballpark force exerted by a 4x 8 sheet of plywood or drywall, or mattress, whatever, moving in air.
Engineers are required here to support or deny with respect to flat solid panels, but I've pilfered a portion of the post from that site not to steal others responses, but to alert WoodCentral readers of some possible considerations of transporting sheets -- like the idiots trying to hold down a mattress on their car roof with their hands while traveling at highway speeds. When considering tying down a 4 x 8 anything to a car roof or rack, you may want to look further into the forces applied.
"....At 42 knots, we have four times the speed (and we are getting close to 50mph or 48.3), so let's compare this to force for the full sheet. From our results above, for each 4" x 4" square we get about 32 x 16 or 512 Newtons, and we can fit 12 x 24 of these into a 4' x 8', or 288, which gives us nearly 15o kN or something like 330 lbf. That's higher than Calvin's estimate, but remember, the sheetrock isn't 100% effective in actually stopping the air, so we should expect a realistic number to be less. One usually uses a coefficient to express the effectiveness of a shape in resisting wind. A coefficient of approximately .6 is actually not too far off from realistic values for a flat plate, and with that we get 198lbf at 48.3mph. I'd say that's in pretty close agreement with Calvin's numbers"...
Again for information only. Hope this serves as something to think about.
I tried to find
Merle
that pic. Thank you for posting it. It is perfect. :)
Robby Wright in San Marcos, CA
Derek - I routinely transport 3 or 4 sheets of stock on the roof rack of our Astro, but there are a few things I do to make sure that it goes well.
First, I keep the leading edge of the sheet back a ways from the front of the car, behind the curve of the windshield. Wind coming up over the front will lift the sheet with a lot of force. Keeping the front of the sheet back where the wind won't catch it as much helps cut this force. When I tie the pieces to the top of the car, I make sure to run at least one rope down the length of the stock and to the front and rear bumpers to take the strain of the wind lift.
Second, you won't accelerate as hard as you brake, especially if you have to stop quickly. I always wrap at least one complete wrap of rope around the stock, forming a choke and secure it to take the force of braking. The harder I brake, the harder the choke cinches down on the wood. I use 1/2" rope for this.
Drive slowly. I grap the stock with one hand so I can feel any movement or lift and adjust my speed accordingly. Since I stay in the slow lane and pull over to let people pass if it is a single lane road, I don't feel guilty. I paid my taxes and get to use the roads too!
A couple of tie-downs across the panels and you are good to go.
Re: Get it rough cut
William Duffield
When he says "rough", he means it. I've used that service at Borgs who must never have sharpened their panel saw blade since the day they installed it. The splinters would challenge Paul Bunyan's orthodontist. That ply is useful for boarding up for a hurricane, but not for building cabinets.
I used to get away with hauling a couple of sheets of 3/4" ply on roof racks, as long as I drove slowly, but when I tried a 1/4" sheet, it got away from me. Luckily, it landed safely. I figured that clamping the ply down on all four corners with quick grips would work, but aerodynamic forces bent and lifted the more flexible sheet at the center, and pulled it out of the jaws of the squeegee clamps. You can never have too many clamps.
