Gremlins are everywhere today!
Stephen Kirk
I'm trying my hand at resawing stock up to 7" thick or so, and it just isn't going well. I see a thing on the floor, and its the allen bolt that holds the carter guides on the lower assembly. Then I see that one of the roller wheels is gone. 45 mins later, after sifting through the dust collector, I find it under the drill press.
Back together, cut a bunch of 3" thick stock and it goes pretty well, still a tiny bit off though.
Run the 6" ash board again and I start seeing a lot of dust flying out. That's because the blade deflected sideways, and contacted the aluminum Kreg fence.
So, brand new blade hits aluminum fence. Seems like the blade is ok, aluminum usually won't hurt them much. Did a test with thinner stock and it came out OK.
Talk about a day of problems. Still not sure why the blade is deflecting on me. But I'm blaming gremlins!
Re: Gremlins are everywhere today!
Sounds like all my days!
Merle
Well, not all my days, but far more than I would like. Most of my problems are of my making so I can't even yell at anybody.
paul in AZ
Blade tension too loose?
Or, the blade's teeth could have a 'set' to them that makes it want to wander.
blade deflection
Bill Tindall, E.TN.
it is usually caused by sawdust clogging up the teeth and loosing clearance. You need a 3 tpi for something that thick and go slow.
Re: blade deflection
Stephen Kirk
Yeah, try again tomorrow going slower. I'm using the 3 tpi Wwodslicer, and it feels like it can cut fast, but that might be misleading.
Tomorrow I'll be making a tall resaw fence too, for better control.
Stephen Kirk
Tension is maxed out and I get between 1/4" and 3/8" flex with the guides all the way up (14"), which seems about right. I'll try changing my feed rate, the likely culprit.
My fear of the blade touching the aluminum fence was that it would damage the set, but I couldn't see any problems.
Dick Coers
Best indicator for feed speed is looking at the kerf when you are done with the cut. Sawdust in the cut, you're feeding too fast, clean kerf means you're feeding correctly. I keep hearing how fast those blades dull. Another indicator on blade deflection.
blade drift problem?
Lars Parrington
stephen, i wonder if the blade hitting your fence might be related to the blade drift problems you reported in an earlier post. i think you said you were getting a tapered cut and were going to try harder to keep the board pressed up against the fence.
you did say that you made a drift adjustment, but maybe it's just not adjusted right. i think if the drift angle of the fence is off it could explain the problems you are having. personally, i find it just about impossible to set the drift angle right. as such, i prefer to resaw by using a single point fence and following a line marked on the board.
i also use a 1/2" woodslicer on a 14" bandsaw.
Bob
Bob
What Bill said about the teeth being clogged by the saw dust. I would try 2 or 3 tpi.
yes that is how you tell you are feeding too fast
Bill Tindall, E.TN.
With apologies to Dick I want to restate this important point and get it in the title to be noticed. When sawdust packs in the teeth the teeth loose clearance and can't correct for deflection. There is some rule I can't remember the details about but it is something like a maximum of a dozen teeth in a cut. The problem of course is that one can't buy a 1.5 tpi blade for a small saw. So, you have to go very slow with a 3 tpi.
Stephen Kirk
I put the tall, single point fence on, and even adjusted the fence back to square. You can see in the picture yesterday's attempt and how the blade deflected in the middle. Today was much better, seen on the right. I slowed down (a lot) and my cut is nearly on, maybe a difference of less than a 1/32" from top to bottom. No more deflection.
Cutting with the single point fence only took some slight practice. My lighting isn't the best, so I grabbed an LED head lamp which is a big help. You do have to mark your cut line, but it's rather easy to follow. I just set my wheel gauge to 3/32", strike the lines, darken with a pencil and cut so I leave the line.
Where's the sawdust????
gary peterson
A little late on the subject, but.... You did state the wood was ash. I had significant trouble trying to resaw white pine with a wood slicer, blade would be all over, did all the adjusting, even bought a new blade. Blade cut oak wonderfully. Tried a reg set 3/8 6tpi and had no difficulty with the pine. New 1/2 reg set blade cut even better. I'd say the set of the teeth wasn't enough to pull the sawdust out with the woodslicer while the wider set on the regular did. just some info
