Not sure I have every had this problem before. I am making a indoor sign for a local bike shop. I am using spray paint in cans.The grain is "ghosting" through even on a sample that I sprayed 2x with gray primer.
I know it works for this application. I used to order it by the 5 gallon pail. No doubt other stuff may work fine too but I have no experience with it.
I just made an "access panel" for a closet wall. Used a chunk of "mystery plywood" from the garage. Rolled on a couple coats of Kilz then one of latex. Looks great.
Kilz is a brand that manufacturers many different primers and paints. They may have a shellac-based primer in their lineup, but they're mostly known for their oil-based and waterborne primers. Zinsser is known for its pigmented, shellac-based primer/sealer.
Thirty years ago I sold paint with Devoe. Many painter ordered and used Kilz to seal interiors that had smoke damage, to seal up the smoke smell. I'm almost sure it was a white pigmented shellac. So either I'm wrong or Kilz has changed sealers since then. Either way: Thanks for the new information.
I have recently used Kilz, both solvent based "Original" and the newer Odorless. I will have to look at the Original can, but it did not seem like a white shellac product to me. Did not smell like it either. OTOH, Bin is a shellac product, or very similar. I had much better results with the Original Kilz. As a friend said, "If it don't stink, it don't work."
The heavier bodied Kilz is better about obscuring grain. There are some stains Bin is better for.
At least for the past 20+ years I have used the solvent based product it is a high solids (42%) alkyd with a ton of pigment. It main attributes are that it dries quick and sands easily. Thinned, it sprays excellent with a conventional gun.
