OT - Smurf tube (ENT) and mice
I'm in the middle of a remodel for a room that will have the TV in it, so I'm scattering boxes around the room with conduits leading to boxes in the crawl space and attic for cables of various sorts (Ethernet, speaker, etc.). Mostly, I was able to use flexible steel conduit, but in a couple of spots I needed the tighter bends I can get with Electrical Non-Metallic Tubing (ENT), known as "smurf tube" in the trade for its color (for those not familiar with it, see picture below).
We live in a small town in an agricultural county, with the creek and flood plain on the east side of town about 1/4 mile away. So we have mice. And rats. I'm doing preventive stuff in the attic and crawl space, but they're persistent devils.
I'm wondering whether I need to be concerned about the rodents chewing through the ENT and making their way into the boxes. The runs in the attic/crawl space will be short, 8-10". Great Stuff has a new foam with a bitter additive that's supposed to discourage varmints; or I could come up with some kind of sleeve (oversize metal flex conduit?). Or I could trust; but I've never found mice/rats terribly trustworthy.
Advice?
Re: OT - Smurf tube (ENT) and mice
Bob Entwisle in NJ
Bill,
Unless it's metal and thick enough so they break their teeth on it, I'd be concerned.
I've know they chew right through ROMEX like it's some sort of a cheese delicacy. I've observed this in horse barns around here.
If rodents are a general local problem, I'd want metal conduit for anything new that I was installing.
just my $0.02 worth.
Bob n NJ
Cable
Run BX steel-armored cable. Don't mistake it for the aluminum shielded stuff.
Bob
Bob
I would use something like BX armor cable. NYC code calls for it for that very reason you posted rats and mice will chew anything.
Personally I would use standard Rigid metallic conduit. This is available at all the Borgs. You can buy a bender for less than $20, if you need to make a 90 degree bend, elbows are available. I'm not sure what they are calling them now, but I always referred to the elbows with a plate on the back as "Factory Ells". Often if you have a real tight bend these make the wire accessible to feed it through easier. As I recall (I rarely used armored cable due to the cost and the fact it was hard to replace wires) the standard EMT was quite a bit cheaper to install than most options. It is also the easiest to pull or replace wires in when a longer run is needed.
Jay Lombardo
Bill, you are right to be concerned. They will eat that stuff. If this is for low voltage, ethernet, thermostat, speaker, etc., I would use flexible metal conduit. BX already has the wires in it so that will not work for your purpose. If you have some particularly tricky spaces to install it in go to an electrical supply house (not a borg) and get some "super flex" greenfield. It is very flexible metal conduit that can be bent very sharply if needed. I would suggest putting a pull string in the flex before you install it and also pull in a new one when you pull in your wires, leave it there for future pulls. It is available in all standard conduit sizes, and the connectors are a little different, but regular take-alls will also work. EMT would work also, but if your not skilled at bending it it would be very frustrating. We make it look easy, it's not :D :D
