OT Glueing Plastic
OT Glueing Plastic
OT Glueing Plastic
Dustmaker Mike
Well I went and bought a 96 jeep to use as a winter beater so I can keep the Shelby warm and dry in the garage. Yesterday I went to replace the headlight assemble on it because it was full of water and really yellow. The instructions say to just grab the bottom and give it a pretty good tug and it pops off of three ball studs. So I tugged it and it popped right off. The problem is the previous owner had glued or epoxied the adjustment screw into the head lamp. When I pulled it off it broke the back housing. It is a black plastic sort of material what can I use to glue it together in temps around 30degs that will hold up? I tried a 5 minute epoxy but that did not hold, maybe JB weld or?
Re: OT Glueing Plastic
Re: OT Glueing Plastic *LINK*
Lars Parrington
many glues don't adhere well to plastics. as an alternative or in addition to gluing, you might try embedding metal wires in the plastic. see this link:
plastic repair (woodgears)
Go
To the local auto graveyard and get yourself a replacement for a few bucks.
Doubtful you'll find a solvent glue for the unknown plastic type involved.
Absent that, wipe the parts with lacquer thinner, and when dry, rough up with 100 grit then use hot-melt glue in and across the seam. That should hold 'til Spring. Come Summer the glue will soften and fail.
Very cool site
Dustmaker Mike
I will have to book mark that
Well I have
Dustmaker Mike
To find one first by the time I get home from work I don't have time to look around maybe this weekend I can find one. Right now a little duct tape holds it in and little wedge keeps it from bouncing around. Thanks
I've never seen a jeep at a junk yard
AZ in Colorado Springs
Jepps get re-built and modified and adapted and re-purposed, but they've never been thrown away
You Need
to visit a better class of junkyards. We have'em by the truckload in Jersey and Eastern PA. :D :D
Allan W
Allan W
Here is a link for plastic welding. I used this to repair the rear bumper on my 07 Toyota.
http://www.urethanesupply.com/
Thanks
Dustmaker Mike
I will look in the local junk yards to see if I can find something a bit cheaper. I do not plan on keeping this for any longer then it take to pay off the wife's car (end of the year) so I really didn't want to get anymore money in it. But I would get a shinny new cool tool out of this :D
I might not need to buy it
Dustmaker Mike
I found a friend with one and he know how to use it now what kind of beer does he drink
Thanks
Alan in Little Washington (NC)
You don't need anything fancy like Lars and Allan show. Go to a plastics shop and they will have small cans of stuff that "solvent welds" most acrylic (Plexiglas), polycarbonate (Lexan), ABS, and other plastics. You hold the parts together and apply a little of the thin, watery, clear solvent to the break line (I use a hypodermic needle). It will wick into and along the break by capillary action. It softens the plastic and allows the parts to bond to each other. It is also available in thicker consistencies. It is not Super Glue (Cyanoacrylate).
A weaker version is available in small glass bottles at all hobby stores. I was doing plastic fabrication so got a 1 pint can of IPS Weld-on solvent adhesive on Ebay.
Way cool that I like
Dustmaker Mike
I just looked I was right next store the the place that sells it near me yesterday getting my glasses. Now I will have to go back and get some cause it looks a whole lot easier then plastic welding in a small space. So I guess my friend don't get the beer, I will let him know it was your fault(-;
But they're just resting, like actors,
between gigs.
