REAL MILK PAINT
Source for spindles
Source for spindles
A.J. Hamler
Source for spindles
A.J. Hamler
I need a source for a specific size (or closer than what I've found) cherry spindle.
One of the projects in my upcoming book is a reproduction of a 19th-century ballot box, of which I own an original:
The project has turned out great, but I want to also offer an alternative for the turned handle for readers who don't own or have experience with a lathe. I've come up with an idea that I think will work, and that's using a cherry spindle -- which you can find by the hundreds online -- which you could cut off and round over the end with a sander. In the image below, you can see the repro handle that I turned, plus the one I made with a spindle I ordered.
The alternative handle would have a slightly different profile and that's OK, and it would mount differently (it would fit into a 1/2" hole to match that tenon on the end instead of being held on by a screw from the inside). The trouble is that I need a spindle that's just slightly larger. The original handle is 1" in diameter, while the largest spindle I can find is only 3/4" in diameter. It'd be good if the spindle was just a bit longer, too. The largest spindle I can find measures 3/4" x 11" -- and I have spent literally weeks online looking. I've found numerous sources for that 3/4" x 11" spindle, but can't find anything larger that doesn't jump up to table-leg size. I really need one 1" x 12", but anything closer than what I've found will do. In addition to looking for spindles, I've tried chair legs, chair parts, balusters, cradle parts, and lots of assorted etceteras.
In a worst case scenario I can go with what I've found even though the handle is only 3/4"; this is an alternative after all, and it will work to make the project accessible to the largest number of people. However, I'd love to find that larger spindle. Does anyone have any idea where I might look? Keep in mind that I've already Googled this to death with no luck, so I'm hoping that someone will have an obscure, but reliable, source.
There are three criteria that absolutely must be filled for these: It MUST involve no lathe on the part of the reader. It MUST be something that a reader could simply order from an existing company -- website, phone order, catalog, whatever. And it MUST be something they could just buy a couple of, no minimum order of a thousand. (Which is what one one company I found demands. They didn't have the larger size or I might have tried to make some kind of deal with them.)
Anybody have any suggestions as to where I could find these?
Thanks!
A.J.
Re: Source for spindles
Re-Source for spindles
john Veerkamp
Old chairs that are past repair will have some spindles in the legs, backs or stretchers that could work and would be really cheap or free. Might not always be cherry, but usually good wood.
Just another possibility to keep stuff out of the dump.
Opportunity
is knocking here, A.J.
As a true repro of the original handle is unavailable, get working on your lathe and turn handles that will be available to those who buy your book for an additional charge!
You can also have them done commercially (anyone with a copy lathe will be happy to make you all you want) and make'em available in a choice of woods as an insert in the book.
:D :D
Carol
Email sent.
