Veritas - Innovation in Tools
Jigsaw problem
Jigsaw problem
Jigsaw problem
Robert Fuller
I have a new B&D Jigsaw. I have put new blades into it and still have the same problem. WhenI try to cut thru a piece of 2x lumber I end up with a cut that looks like partwaqy thru the saw blade was bending.
In other words, to exaggerate it the cut looks like I was cutting out a tapered hole. It does not matter how slow I feed or how fast the saw is running.
Obviously this must be related to the saw blade bending in the kerf, but is there a reason for it and can I fix this?
Re: Jigsaw problem
Re: Jigsaw problem
In my experience, consumer grade saber (jig) saws suffer from this a lot.
Even the professional saws ($150 or so new) aren't perfect - you are, after all, asking a blade of small section to remain straight in thick wood while you apply stress both forward and sideways. But they're a lot better.
This is one of the times when there's a huge quality break between the consumer-grade stuff and the pro-grade stuff. If you're doing a lot of this kind of work, consider a Bosch (my favorite), DeWalt, or other pro-grade saw.
If the price makes you flinch, look for a reconditioned saw.
Re: Jigsaw problem
Re: Jigsaw problem
Stephen Kirk
If you haven't already, try putting in an aggressive blade. Cut quality will suffer, but it may make the cut easy enough not to bend the blade.
Check the bevel plate on the saw too, they can come loose. Sometimes they need to be cranked down hard.
I also went from Sears brand to a Bosche - bunch more expensive but it works very well. It's my main stock breakdown tool.
Re: Jigsaw problem
Try A Different Blade
Dave's Not Here
Go to Home Depot and get a pack of Bosch T234 Progressor Blades. They are a very aggressive blade and a little thicker than most. A better quality jigsaw would also make a difference however sometimes all that's needed is just a better quality blade.
Re: Jigsaw problem
Re: Jigsaw problem
del schisler
i never saw a jig saw that would cut a streight line thro most anything, in my opion that is about the worst saw that that has been made, i gave mine away yrs ago and wouldn't carry one home for free my 2 cent's
Re: Jigsaw problem
Re: Jigsaw problem
Clementine
We had this same discussion on the hand tools side a couple of weeks ago. The general consensus was to either get one of the top of the line jigsaws or, even better, a compass saw. My next tool purchase will be a Shark compass saw.
Re: Jigsaw problem
Re: Jigsaw problem
Kurt
"If you're doing a lot of this kind of work, consider a Bosch (my favorite), DeWalt, or other pro-grade saw.
If the price makes you flinch, look for a reconditioned saw."
Look first at a Festool. After that, any other will seem pretty reasonable ;-). You could keep an eye on cpobosch.com. I have a reconditioned 1587 and except for the 'refurb' engraved on the case, you'd never know it wasn't new.
