Raised Panel - Wide Reveal out of Style?
David Weaver
About 6 years ago, I found a nice freud set on sale and bought it, knowing that I would be building kitchen cabinets soon.
Well, that time has arrived and I think I like the raised panel doors with a smaller reveal better.
Is it just me, or does it seem like doors with a thinner rail and style and less reveal are becoming more popular (and look better, too)?
(not talking about flat panel doors, the doors will be raised panel).
I can't find any bits that look.
Re: Raised Panel - Wide Reveal out of Style?
Aesthetics
By reveal, I'm reading "bevel," David. I hope that's what you mean. At any rate, the look of cabinet doors is a decision you need to make for yourself, according to whatever criteria are important to you. There are a few absolutes, such as that the doors must stay together and flat, and those are largely engineering concerns. The actual look is up to you (or whoever the customer is, perhaps your wife).
Wide bevels were common on Colonial era furniture and architecture. I happen to like that look a lot, partly on purely aesthetic grounds, but also because they don't look like they came off a router bit. As for stiles and rails, their widths are part of the elevations of the room, and they need to look good together and with the overall look of the room. That could mean any width, but there is a range of width and proportion that is neither too wide nor too narrow-looking. You and your customer should look at measured elevation drawings and decide what works best.
Re: Aesthetics
David Weaver
I'd say I wish I had a customer, but I don't. I'm the customer.
I'm pretty much going to take the cabinets out of my kitchen and put new ones in where the old ones are. I like the layout of the old ones, height, etc. That leaves me with some narrow doors and some wide doors. The narrowest will be planned out, but some of the doors will be about 11 inches wide and 24 tall, which can make for an awkward center panel when the bevel is wide. Most of the doors are much wider, though. I'll stick with the regular "wide" bevel, which will end up being about 1 1/4" outside of the groove in the door, but I ditched the cove profile in exchange for a flat bevel by ordering a different bit set this morning.
You're right, by reveal, I mean bevel.
I'll make a couple of sample doors out of poplar and see how they look in terms of the rails and styles. I don't want them to be too narrow, or they look like older RTA cabinets that minimized the use of solid wood. What I should probably do is go to a kitchen place and sneak around with a pocket rule and document what looks good to me.
I remember the doors we made at the cabinet factory when I was there. They had very wide rails and stiles if they were natural wood.
I'll probably shoot for somewhere between.
Making a lot of something where the joints aren't fit with handtools and solid wood as you go along is a bit of a change of pace for me (or a huge one, that is).
Like everything else, I'll needle about these aesthetics, but in the end I'm sure the stuff will be fine. You can get used to anything decent as the occupant of the house.
Thanks for entertaining an otherwise dull question that I guess really only goes by opinion.
