Router a fly reel
Router a fly reel
Router a fly reel
Jack Putnam
I am working on a project that requires some router work. I'll try to make this simple. I have a piece of wood 4 1/2 inches in diamiter and 1 inch thick. I am making a sample of a fly reel and I need to make a ridge on the outside of the reel about 1/16 wide. Picture the reel laying flat. Between the two outside 1/16 wide ridges, I need to router out about 11/16 wide of the inside of this area to simulate where the fly line is. I thought of using a dremel tool because the reel is small a large router would be to big. I am thinking of some kind of a jig one holding the dremel tool on one side and across from the dremel tool a jig holding the round reel.
I don't know what kind of router bit to use or how I am going to be able to turn the fly reel to cut in to the side of the reel. I want to cut it about 1/8 deep all around. Hope you can picture this there has to be some kind of a jig to make this easy. I tried to router one piece of wood and the dremel router bit I used started out fine with the router holder, I tried to run it around the top of the wood with the bit cutting into the side of the wood but it tore the edge up bad. I would appreciate any help you can give me. Thanks.
Re: Router a fly reel
make it in 3 pieces, then laminate
Dick Coers
the thin pieces to the large central hum. That will also make sanding easier.
Joseph Mulherin, sr
Jack, if you have a lathe or drill press this is what I would suggest:
drill a 3/8" hole in the blank center, install a 3/8" qall thread rod
thru it and then put nuts on each side tight. I would cut the rim
inside on the reel with a hacksaw blade to get the outside of the
reel line space to any depth you want without chink out any wood.
Then I would use a lathe cutoff chisel to smooth out the lone space
with it to any depth you wish.
Just my idea for you... Joe in Indio, Ca
Jack Putnam
Thanks for the two responses but I forgot to add that the bottom of the fly reel is flat and that the top of the fly reel has a cross bar that supports a fly rod. So it's impossible to put it on a lathe to route out the center part. I can only router half of one side and stop then do the other side. With the brake in between the top and bottom this is what is where the problem is.
I'd use a wood lathe
Joseph Mulherin, sr
OK, it seems we were given the correct aspect of just you were seeking to find out to produce.
Still my idea would make the reel and you could still add they rod into the reel.
In addition I would use your Dremel small bit and go around the outside of the reel to
make some triangular area like on the real reels.
Bob
Bob
Can you use a circle cutting jig in some fashion? Start with a larger square piece and make your depth cuts then cut it free with a smaller bit use double stick tape to hold it still and to keep it from flying out of the outer part?
Ralph Lipeles
Or spin it using your setup and a table saw to cut away the inside material.
Ralph Lipeles
TomD
When they make the actual fly reels out of bar stock, they probably set them up in a mill with a rotating table. So the reel would be vertical in the position it hangs from the rod. And then they rotate the reel till the full width bit takes the cuts out. They either use a pipe section for this component, of more likely today, they have roughed out solid stock one a lather, or CNC. So these cuts only punch through the wall. But I gather you want to just make Faux cuts and are going to retain the central mass of the wood?
So one way to do that on a router table (or with a base). Is to make a full height fence, then place a v strip of wood so the reel can sit in there and be rotated over the bit. This could be faily safe since the cuts are very light. But you have to be familiar with feeds etc.. with routers, and if you were, you might not be needling to ask this question.
I would cut the reel foot off, and handle the whole piece as a round. The feet, are not normally integral, though I suppose with CNC anything is possible. The foot will be a lot in the way until you get your piece where you want it.
