MultiMaster Tool...How Do I Get It To Work?
Derek Arita
I've had my Fein MultMaster tool for about 8 years years now. It's the older style, with a screw that holds the attachments. When I'm not using it, I think of it as a tool that, when needed, is priceless and I'm glad I paid the almost $400 for it. Whenever I actually have to use the tool, I get so frustrated trying to make it work right, that I end up tossing it back in the case and using another method to accomplish my task.
What happens is, every time I try to use one of the saw blades to make a cut in wood, the blade invariably comes loose. At best, the blade burns it's way thru the wood until again, the blade comes loose. When the little adapter washer for the new style blades came out, I got a couple, but it hasn't made any difference. I tighten down on the screw just as tight as I dare and the blade still comes loose.
I called Fein for tech help and the tech told me that I was using the wrong screw to hold the blades. He said the kit comes with two screws and that I should use the "other" screw and all will be good. Even though to my eye, both screws looked the same, I tried it and found no difference.
To this day, I don't know it that guy was just yanking my chain or what.
What the _____ am I doing wrong? I know that others use the MultiMaster with success, so it must be something I'm either not doing or doing wrong. Why can't I get this $400 tool to work the way it's supposed to work?!!!
Re: MultiMaster Tool...How Do I Get It To Work?
Jason Roehl in Lafayette, IN
I don't have the screw-type model, I have the newer clamped-blade model, so I can't speak to that problem specifically, but it may be related to something else I gleaned from your post.
When I first got mine, I thought it was the bee's knees, except that it was eating blades like there was no tomorrow. I could tell that it was saving me a huge amount of time on the particular job I first used it, so I didn't really care. Over time though, I figured out that I couldn't just crank the speed all the way up and bear down and expect magic to happen. Sometimes, less is more. Heat is your enemy, and since these oscillating tools don't move the blades very far but move it quickly, and they're designed to get buried in the cut, there's very little heat dissipation. You have to keep the blade moving, and clear sawdust fairly often.
How does that apply to your blade-loosening problem? Perhaps the over-heating/cooling cycles are causing the screw to loosen as you use it.
Jason
Derek Arita
Jason, that might be the case. I can tell you that I have tried different techniques, like a soft touch, all the way to baring down on the tool...none seem to work for me. When I use a soft touch, the blade doesn't come loose, but it doesn't cut worth a darn either.
I've done some research and found that others have had the same issue, but I have not found a solution. What I did find is that others got so frustrated, that they went to Harbor Freight and bought their multi tool and were pleased with the way it works. They said the blade never comes loose and it cuts like it should. Heaven help me, I'm about to go to HF and get one, just to make a comparison. If the HF one works well, why can't I get the Fein to do the same?
Have you tried
Merle
Loctite Blue 242? Do NOT use Loctite Red 271 unless you want a pemanent installation. HTH
Re: Have you tried
Derek Arita
No, I haven't tried Loctite as of yet. Although that may work, I don't think I should have to resort to that, to make the tool work. That said, desperate times, call for desperate measures...
John McGaw
I don't have that tool but I do have the really cheap Dremel knockoff which cost all of $75 refurbished. It uses a screw and I've never had one come loose. Does yours use any sort of lock washer? Are you applying forces to the tool which it might not be expecting? If any part of the blade except the cutting edge is touching the workpiece then there might be unbalanced forces causing the problem Virtually no force is required to cut woods with mine -- 'let the tool do the work' as they say.
You're not alone
Henry Higginbotham
Everybody who bought one of the earlier models had the same problem, unless they only used it to slice soggy toast.
In my opinion, it worked so poorly that Fein should have produced a replacement head for the tool that incorporated the newer blade mount, and should have HEAVILY subsidized the cost to the consumer to upgrade.
Instead, they came out with solutions like the grit washer ($7, if I recall), which helped only somewhat. What I wound up doing was replacing the socket-head cap screw with a hex-head cap screw (M6x1, I think), allowing me to grunk it down tighter. This is a game of brinksmanship: The higher torque may someday destroy the blade mount, but without it the tool is useless anyway.
In the end, though, when it is working, it's a wonderfully effective tool, so I grudgingly tolerate the bad design.
Neal in San Jose
What I have found is that it helps to have all of the parts as clean as I can get them. I've used compressed air to blow everything off or paint/lacquer thinner and a small brush.
I agree that changing speed and/or pressure is of minimal help so i just crank 'er up and lean on it until the blade loosens. Then I pick a few choice swear words, resist the temptation to throw it out the window, clean everything up and try again.
I used a friend's battery powered Bosch and found it to have the same issue, just maybe not quite as bad.
Odd...I ave the battery powered Bosch....
and used it until I wore it out. Never remember the blade coming loose. At least not enough to be an issue. I bought cheap blades at HF and others and used the grit washer. It had the screw. When it was reaching the end of its useful life I bought a new corded Bosch that has the blade clamp built in and it works like a champ and has a lot more "horses" than the battery powered one ever had. As I recall, I paid under a $100 for the first one and less than $200 for the second one. I would consider having the battery one rebuilt. We find endless work for the tool remodeling houses.
Unfortunately I have no idea how to help Derek.
It's not the screw diff, it's the washer *LINK*
Dick Coers
The small washer/screw is for pads, the large washer/screw is for the blades. I think I've only had a blade come loose about twice. I didn't read all the posts, but let it do the cutting. This is a finesse tool, not a chain saw.
http://www.jamestowndistributors.com/userportal/product.do?part=5627&engine=adwords!6456&keyword=product_ad_3323&type=pla
Re: Odd...I ave the battery powered Bosch....
Derek Arita
Well, I looked in the case again and saw two screws, but both washers were the same size. Guess I never got the larger washer. At any rate, I'll get a new screw set and give it another try.
Meantime, I went down to HF and picked up their variable speed multitool for $32, with 20% off coupon. I used it on a project and I have to say, it works just like I thought the Fein would. The blade never came loose and it cuts very nicely. Could have saved myself a lot a $. At this price, when the HF version of the lever type head comes out, I'll get one of those as well.
Re: The HF the blade comes loose too.
Jason Waters
I started with the HF one for like $25 which uses an allen screw. HF's directions leave a little to be desired, but I found you have to assemble the cupped washers correctly. And it still works loose too.
I later bought a Fein with the new style blade clamp and have no issues.
