I just built a shop cabinet/outfeed table for my table saw. I have it on rollers so that I can move it out of the way in my little garage shop, when necessary. I'd like to be able to stabilize the table as well, because I have a wood vise mounted to it that may require a solid base, when in use. I thought about using some large push clamps, mounted low on the sides and extending down to the ground, but that might not be stable enough. The table is currently just at the right height, so it can't be raised up any. I'm looking for other ideas.
How about some rotating blocks, a bit like a bike kick stand? If engineered right, those would only raise the table maybe 1/8" in use.
Not sure what push clamps are, but I would expect any kind of bar clamp to be a pretty good tripping/shin hazard, and unless you have some really beefy clamping the legs would likely shift under heavy use (like hand planing for example).
Jorgensen used to make some screw hold down clamps that could work for you. They had a pin that you can let into the wood and just push out to engage the clamp, so the clamp is removeable when not in use. You'd probably need 4 or 8 of those though, and that would get pretty expensive.
I think I might change my original thought. I considered somehow latching the outfeed table top to the rear angle stock on the saw, but I gave up on that for fear of possibly tweaking the saw table during hard use of the vise.
I don't know...maybe I'm asking too much...maybe I should leave the vice off or accept a little wiggle when i use the vice.
Paul, Yeah...I probably should have started with locking castors or something like that. Problem is, I already had the wheels I used, mortised in and mounted. What I need is a workbench to mount the vice in, but I had to work every scheme I knew to get the wife to approve the little room I have in the two car garage. That's why I'm trying to squeeze everything I can into this outfeed table/cabinet/workbench.
On the workbench / catch table for my jobsite table saw, I set the legs back about a foot from the end, so the vice could be out past the leg. Then on the bottom of the end legs, I cut a bevel so I could mount the rollers on the side, rather than on the bottom. The rollers just touch the floor.
When the bench is just sitting on the floor, it sits on all four legs. But when I lift the other end, it is up on those two wheels, ready to roll, as if it were on a dolly. This bench is only about 4' long, so the higher I lift, the more the center of gravity moves over those two wheels, so it is just a mater of balancing it when I wheel it around.
Good idea putting wheels on the sides of the legs. I'd like to be able to use that here, however the cabinet under the table will be loaded with stuff and will likely be pretty heavy. That said, it's something I'll have to consider, as it may be a good solution to my problem. Thanks.
