OT picture sizing help needed
McKay
I use infra view to re-size my pictures to post here on WC. I tried to re-size the pictures so that I could print off a hard copy at Costco. Costcos machines truncate the pictures because they are 4800 x 3600. This operation then cuts off most of the picture because it is square. I have tried to re-size the pictures to 1200 x 1800 to make the pic. fit in a 4x6 print, but infra view changes the pic. back to some squarish pixel number. What can I do to get a good print? Thanks in advance.
Re: OT picture sizing help needed
John McGaw
Irfranview is pretty straightforward when it comes to resizing and I've never seen it fail yet. (I'm using version 4.35 right now) I'll admit that I don't really know what you mean when you write "This operation then cuts off most of the picture because it is square." What operation is that? Resizing or printing? If the original image is in the proportions you gave then it isn't starting out square. If you are trying to make it square you want to be cropping, not resizing.
I would try again making sure that the checkbox in Irfranview for "preserve aspect ratio" is checked and then just change one of the dimensions for the target image and try again. i.e. just change the height or the width and leave the other dimension alone. If you are starting with 4800X3600 and asking the program to make it 1200X1800 I can't see how it will ever work properly and if you did pull it off then it would probably be pretty strange looking.
To be honest I can't see why any photo kiosk software (as in Costco's) would fail to print any size image you want from whatever image size you feed it. Is there anybody there at the store to ask? 4800X3600 just isn't that huge an image in modern terms and it should be easily managed.
Doug in Utah
Picasa3 will do what you want. In the drop down under Crop set it to 4x6.
