Elaboration
Elaboration
Elaboration
Kelly Craig
At Russ' Pages you state: "A personal opinion that may not be shared by many others is that - If you wouldn't put motor oil on your wood, why would you use Mineral Oil? Mineral Oil is a more highly refined form of motor oil."
There are times when non-hardening oils are the best treatment. Think, for example, about old butcher blocks, some of which are more than a foot thick. Being made of wood, they dry and shrink over the years, which results in splits and cracks. This, of course, applies to any wood surface.
If you used a hardening oil, a varnish or other drying or hardening finish, you could never get the spits and cracks to disappear. To do that, you have to swell the wood back to its original state. Initial coats of hardening finishes would seal out future coats.
To restore such surfaces, be it a butcher block or a deck, you have to swell the wood back to the state it was in originally.
I have restored old butcher blocks by merely adding mineral oil, allowing it to set and soak in, then adding more until it stopped soaking it in. After that, I just walked away and ignored the project for a few weeks. This allowed the mineral oil to wick deeper into the wood and swell the wood fibers. Eventually, the wood expanded back to it's original state. Often, every crack and split disappeared.
Once the block swelled to the point it was at, established by its original moisture content, you can apply a seal coat to lock the oil in. However, if I was going to use the chopping block for its original purpose, I'd avoid building a surface coat, which would chip with use. You might want to just seal with bee's wax, which could be softened with turpentine.
You can put the wax in a pan and place that pan in another filled with boiling water, away from heat sources, to avoid the danger otherwise associated with turpentine and heat sources. Of course, you would add more boiling water, as needed.
Re: Elaboration
Bob
Re: Elaboration
Bob
A fine explanation and OH so true, I would stay away from the turps though if its for food prep. Just my preference mind you, but I do mix bees wax and mineral oil as a last coat.
Re: Elaboration
what a silly statement
Well I would agree that the statement is fundamentally flawed. Mineral oil has so little to do with motor oil as to be just silly. By the same logic one wouldn't eat steak because cows have hair and guts.
Re: Elaboration
Re: what a silly statement
TomD
Though, mineral oil does make a good oil for machinery when available in the weights that match uses.
