Using A New Dado Technique...New To Me...
Derek Arita
OK...So I was trying to figure out a different way to do some dados, other than on the TS. I liked some of the jigs I've seen, but didn't want to buy another jig. I already have a Festool OF1400 and guide rail, so I figured out a way to do the same thing that jigs do, without the jig. The technique can be done with other routers using guide rails. I'm sure a lot of you have already figured this out, but this is new to me, so I thought I'd share...
I set up the router as usual, using the router "Guide Rail Stop", which is Festool's name for the router guide rail adapter. Since I'm using a 1/2" upcut bit for a 3/4" dado, I use a 1/2" gauge block to space the router exactly 1/2" from the rail edge.
I then run the first pass. For the second pass, I replace the gauge block with a piece of the actual material that's going to fit into the dado, along with a .008" feeler gauge piece, for glue spacing and plywood imperfections.
[URL=http://imageshack.us/photo/my-images/5/img0612wc.jpg/]
[/URL]
After making the second pass, I get a dado that is consistently just the right size for that piece of plywood.
Comments?
