help with Glide Criss Cross Install
Geoff in Madison
I am wondering if anyone has recently installed a Benchcrafted Crisscross on a bench. I'm in the process of doing that now following the Benchcrafted instructions. According to the instructions the leg vise is supposed to have some toe-in towards the top. Mine does toe-in, but there is a 5/8" gap at the bottom which seems far too wide.
I've double checked the measurements of the mortises required for the crisscross and the positioning of the steel pivot rods and those are within 1/64" of what the directions call for.
At the bottom of each mortise for the criss cross (in the bench leg and the vise chop, the instructions have me installing two steel wear plates. Without these wear plates there is only a 3/16" gap. I'm wondering if I need to deepen the mortise where those plates go.
Thanks,
Geoff
Re: help with Glide Criss Cross Install
Steve Kirincich
Hi Geoff,
Have you considered contacting Jameel at Benchcrafted? He has helped me as I complete my Glide vise installation.
Steve
Geoff in Madison
Yes, I did yesterday, but haven't heard anything yet so I thought I would try other sources as well.
