Pedestal Table Design Guidelines
Don Stephan
Wondering if there are any general guidelines for the pedestal component of pedestal dining tables. "Pedestal" is used to include a base, the column itself, and a sub-top. It is assumed that a 1/2" threaded rod will securely connect these three components. The base may sit directly on the floor or on bun or similar feet, and the sub-top is connected with screws or other fastening system to the top itself.
For a square or round tabletop, my understanding is that a solid base (similarly square or round) should reach within ten inches of the "drip line" of the top. For an X-shaped base my inclination would be to similarly size the length of the X members.
For an oval or elliptical tabletop, a similar 10" guideline for a solid oval or elliptical base would seem likely to provide good tip resistance if flat on the floor. As the length of an oval or elliptical table gets proportionally larger than the width, the tipping potential for bun feet under a solid base and alternatively for an X-shaped base would seem to increase.
Anyone have a general rule when to use two pedestals rather than one, as the length of an oval or elliptical top gets proportionally greater than the width?
Related discussion also welcome, as I don't have much reference materials on pedestal table design.
Thanks.
