Harbor Freight Clamps?
Derek Arita
Just looking for opinions on the aluminum extruded clamps and their pipe clamps. Any good? Do the aluminum clamps flex? Do the pipe clamps hold 90* under pressure?
Re: Harbor Freight Clamps?
Henry (Raleigh, NC)
I have a few varieties of HF clamps - that invariably fail. These are the only clamps I own that have failed - any of my other brands have held up to whatever I have asked of them.
So for light duty use, they are fine. For any heavy duty clamping - consider paying more for what you need.
Henry
Dave's Not Here
If you can afford better quality clamps, definitely go that route. I have zero experience with the HF aluminum bar clamps but I do have some F clamps and pipe clamps. The pipe clamps are just OK and the obvious lesser quality level is apparent when placed side by side with the likes of Pony's and others.
TomD
I have not tried the HF clamps, but discount clamps have turned out to be useless. You would think it would be a natural for cheap manufacture, but they can't seem to pull it off.
Clementine
Been there. Done that. Not again.
I haven't owned those, but I had some Hazard Fraught bar clamps, and they failed to make the tiny notches in the bar deep enough to catch the sliding jaw, so it did exactly what the description says, and slid - every time you tried to tighten it up.
It would have been easy enough to take a cold chisel and spend an afternoon chiseling the notches deeper, but it was even easier to find some better bar clamps at a yard sale.
Bob
Bob
Garbage! Do own them any more I sent them to the scrap guy that comes around once a week I tried to use them two times and they failed, I took the first set back and they gave me replacements two days later I took them back again but they were not so kind so the scrap man has them now.
Jim Hoeller
I have a pair of the aluminum bar clamps and several "F" style 6" and 12" clamps. I am satisfied with their performance and the prices were a lot lower than alternative sources.
