REAL MILK PAINT
Cut Brass With Carbide Blade?
Derek Arita
I have some 1/2" brass stock that I need to cut. Can I really cut it safely with a regular carbide miter saw blade? Will it harm the blade?
Re: Cut Brass With Carbide Blade?
Keith Newton
1/2" is only one of a 3D object. Could you give a bit more to help us understand what you are cutting.
If you are cutting a 1/2" round, yes, go for it. If it is 1/2" thick x 6" wide, I wouldn't use a miter saw, since the teeth would be in the cut too long. Using the TS with a sled would be better.
In any case, a low, or negative hook triple chip blade would be best. And high hook angle blade like for ripping would be less good, and would dull faster.
My preferences would be to use a band saw - depending on which blade you have on the band saw. Not a Wood Slicer of course - but some of the good bi-metal blades work well for both wood and metal. Also - all brass is not equal. Some is much harder than others.
Generally
not a great idea, depending also (as was mentioned) on the alloy. Brass and bronze are "sticky" meaning they will leave residue on a dry blade that increases friction and heat. Wood working blades usually move at a much higher speed that those designed to cut metals, even non-ferrous metals.
Consider also that your miter saw (RAS as well) is an open blade situation. If you get a "catch" you can have shrapnel flying around you, and even without a catch, you'll have fine metal dust flying around.
A metal-cutting band saw, with its slower speed and thicker blade would be much preferred.
ditto
Metal cutting blades are designed with different carbide and different tooth geometry. Damned if I would risk an $80 blade and injury cutting brass.
Re: ditto
Robert Fuller
+2 on the use of a bandsaw instead of miter or table saw.
With the right blade, yes
John in NM
Dry cut non-ferrous metal blades have 0 or negative hook and square teeth. I would not recommend it using a CMS unless you are extremely cautious, as the sliding action can cause you problems. Using a regular chop saw with the proper blade will be fine, it is done in industry all the time - that is why those blades exist.
I've cut aluminum often with chop saws and router (horrible! :D ). Never tried brass - it is harder but less sticky than most aluminum alloys. The blade manufacturer should have info on which blade to use.
Ear protection is a must, and really good eye protection, closed goggles or regular glasses with a face shield.
Re: With the right blade, yes
Jason Waters
Not all CMS (Compound Miter Saws) are sliders. My Dewalt 705 is just a Compound Miter Saw. A Chop saw doesn't tilt the blade, ie, it only rotates the table left right for angle cuts across the flat table portion. At least that's my understanding of how these tools should be described.
I definately wouldn't use a slider.
If I did cut brass (and I have), I would use a blade designed for it. That being said, I do have a Metal cutting blade for mine, which I bought to cut aluminum extrusion for some work I did at the house. I have used it to cut brass tubing, but not solid pieces. If I was cutting only 1 or 2 pieces, I'd use a hacksaw, cut long, and square up on the disc sander, or even a with a file.
? that should be asked, will it harm you
Dick Coers
I've had too many explosions cutting plexiglas on the miter saw. Won't do it again, won't ever cut anything but wood unless the blade is for the application and a sub fence is installed with zero clearance.
You're right, CSMS rather than CMS...
John in NM
Durn acronyms! :D
I've done it in a pinch with a slider, but I really, really don't like it :D Regular saw is much better.
Re: ? that should be asked, will it harm you
Jason Waters
It only took one explosion of plexiglass for me never to cut it again on the mitersaw. I agree. Caution should always be used.
Pete in Holland, MI
Once you have the right blade:
1) Faceshield. This isn't sawdust. It's metal shavings which will be hot and sharp.
2) Metal shavings can get into open case motors and make for electrical shorts.
3) A small cut off, caught by the blade, could become a bullet.
Advise against it.
Pete
Re: Quality Jig Saw
TomD
A good one like the Boesch with a metal cutting blade is quite effective. I have not tried 1/2" brass but it whips through aluminum. You need the blade set with zero oscillation. I have two metal bandsaws, so that is where I am at this point. You can pick up the little ones for about 100 bucks and they give good service. Check out the HF dumpster if you have one near you. A lot of tools end up in there, and once you grab a couple, you normally have a good one. Sometimes the problems are only cosmetic. It does not take a lot of to cut metal, a slow speed, a proper blade, and enough feed pressure. So for instance you can shoot holes in metal easily with a brace and bit.
Re: Quality Jig Saw
Derek Arita
I used an old carbide blade on a an old miter saw and made the cut. Came out fine. Thanks for the help!
Tell me about these explosions, please.
Tim Greif - West of Chicago
I'm really curious about you guys' experience with the exploding plexiglas on a miter saw.
Reason I say that is that I've successfully cut plexi a number of times on my RAS, using both positive and negative hook crosscut blades. Never a problem. I've also miter cut aluminum picture frame material on both the RAS and my Makita non-slider CMS using a 70 tooth blade.
What would make the plexi explode on a miter saw?
