Raw wood got wet, staining is causing blotches
Jeff Lambert
I am a novice. I have been enjoying restoring antiques for a few years now. Well I decided to do it on a much larger scale and bought a 100 year old antique house(my wife's dream). I have been working since the 1st of September. Getting really close to completing everything hopefully in a month. First things first my brother busted a pipe in the kitchen water got all over the maple cabinet shells that I just finished stripping and sanding. We waited a few weeks and stained them. The water based stain was darker in some spots and lighter and thoughts were because of the water that splashed onto them. Then I just completed sanding all the doors to the cabinets but the wifey wanted to bring them home to stain on her spare time. We don't live there yet. Well it started raining halfway home. I pulled over where I could to throw tarp over cabinets but some still got wet. We let them fan and air dry for a week in hopes that we wouldn't have the same problem with the stain and I sanded again with a 220 grit. Also my other question is we are using a tack cloth to remove dust is this a bad idea or the cause of this?
Any help would be great.
Re: Raw wood got wet, staining is causing blotches
Dick Coers
Any time wood gets wet, the cells expand. Locally damp sections of the wood will have some cells open, some closed from sanding, so unequal staining. Resand the wood completely, wipe down the entire work with a damp cloth, let dry, sand lightly again, then stain again. A gel stain, or solvent based stain will not "bite" into the wood as much as a water based stain. I've had drops of sweat show up during staining for the same reason.
Dog Saliva!
Tony-Memphis
My wife's old dog loved cherry. He would come into the shop and lick it. I missed a lick and there is a permanent spot on a cabinet door panel where he left his mark. Kind of sentinmental now as he RIP. Not mahogany, not maple, etc,. just cherry.
Tony
What Dick said - a good water based stain should work. Alternatively, a good dye would also work.
Jeff Lambert
What was used was a water based stain. So use a gel or oil based stain?
Not  Yet
resand the pieces first. Start at 150, goto 180, finish at 220. vacuum off the dust as you change grits (forget the tack rag, that's for finish surfaces.
Next use a pre-stain conditioner to even out the porosity of the wood. Minwax makes one or you can make your own using 100% dewaxed shellac in a very dilute (1/2lb cut) mix. Apply the conditioner, let dry for 15 min., lightly sand with 220, vacuum off well, then go with a wiping gel stain per can directions. Let dry well for a day or so before top coating with your finish. If you want to use a water-based top coat, it's often best to seal the wood and stain with another coat of shellac mixed to at least a 1 lb. cut. Shellac technology is ancient and modern, and is something you should learn if you're doing a lot of finishing, especially refinishing of old wood.
Your public library will have any number of good books on finishing. Look for authors under the names of Jewitt, Flexner, and Dresdner to name a few.
I quit using the Tack rags three or 4 years ago. I buy the "microfiber" cloths in bundles at Sam's club. I have a pretty good filter on my compressor so blow off the loose dust - then wipe down well with the microfiber. In my opinion they clean better than the Tack rags, leave no residue and are washable.
Re: Not  Yet
Jeff Lambert
I will try these few things and see what happens. I will definitely report back on this. I appreciate all the advice.
