THE WOODRAT IS BACK!
Work space
Work space
Bob
Work space
Bob
I am trying to figure out how many wood worker can use 1800 sq feet at the same time safely, with out getting in each others way in a fully equipped shop. This is for a wood working club. The club is getting a new building and I am trying to be reasonable as to what I ask for. I am guessing 10 to 15 people at once is there a rule?
Thanks Something like this.
Re: Work space
Re: Work space
Brian from Monument
You need to define fully equipped for us.
Layout the power tools if any...... I assume some.
What open space is left over is bench space.
I would separate it from the machine area.
There may be a need for a physical partition, perhaps for insurance reasons.
Or just for control reasons.
Do remember to leave adequate passage ways between benches.
I would expect each bench to need some real estate near them.
The size of the benches is critical to this decision path.
Plus the type of projects the people are working on.
Are all benches the same size/purpose etc?
Re: Work space
Re: Work space
Jesse Cloud
If its 300 ft x 60 feet, as the diagram suggests, then you have 18000 sq ft which would certainly be plenty of space for 15 people. Probably the limiting factor will be multiple people wanting to use the same machine.
Its very helpful in an environment like this to have some rules about setups (once I get the table saw set just right, can I keep others from using it while I go to lunch, use another machine, etc. Another good rule is how long can I leave work in progress in the shop - some places insist that glue ups must be put away by say noon the next day.
Be sure to have lots of benches/tables for sanding, assembly etc.
Re: Work space
Re: Work space
Keith Newton
Bob, Rather than spacing individual tools out in the middle of the floor, I have found it to be handier to do groupings, which fit back to back, even forming triangles of their in and out feed path which they share. Also, think of material flow. It is nice to have storage near a door where it comes in. Then maybe the next stop is a table-saw, which should have plenty room around it. But then close by, the next step, will be jointer, thickness planer, or miter saw.
Re: Work space
Bob
Re: Work space
Bob
That should be 30' if you look at the back it shows it. I forgot to delete the 300 which sketch up put in when I drew it.
Re: Work space
Bob
Re: Work space
Bob
Someone suggested to me that I should call one of the schools like the Bennett St school or one of the others. I will give that a try as I am sure there is a DHS or OSHA requirement that people go by.
Thanks Guys
Re: Work space
Re: Work space
Robert Fuller
As I read the drawing it is 300 inches as shown, or 25 feet.
IMO 10-15 people in that space all working on individual projects or processes would be a bit crowded.
However, if a few are actually working and the others are watching, as in a classroom environment, that is certainly suitable.
