A55 Smoothing Plane
bench top cross cut sled
Jerry Gibbs
I have a 10" Ryobi bench top ts which I like. It serves my purpose. The miter gauge is flimsy. I want to build a cross cut sled. The miter slots are approximately 5/8" wide and 5/16" deep. I can make runners for these dimensions. The problem is that the slots have tabs on the top to form a sort of T track. The tabs create a problem for me to make a small or odd shaped runner. Do you think there is any problem removing the tabs? I could care less if Ryobi claims I made the saw dangerous. I also don't care about the miter gauge being contained by the tabs. Any suggestions for a sled are appreciated. I took a picture but I gave up trying to resize the photo. Jerry
Re: bench top cross cut sled
Paul Vander Woude
Why not just make the sled's runners to the dimension of the narrow, top part of the slot?
Jerry Gibbs
Re: photo
Can you find pieces of metal the "wider" width of the slot but thin enough to slide under those tabs? Then you could make some sort of stand offs to slide between the tabs.
Robert Hayward
I would file off the eight ears and be done with it.
You could also mill the wood to the shape of the current miter slide.
Bob
Robert Fuller
Those tabs are there for a reason (what it is is someone elses guess) so leave them be. Just make the runners the same (or similar) shape as the miter gauge. You did say the miter gauge was sloppy so maybe make the runners a bit larger and tweak their size till you get a tight fit that runs in the slot smoothly.
